My new 521
  • Please log in to reply
382 replies to this topic
#361 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
  • Cars:72 Datsun 521
Posted 21 June 2017 - 11:19 AM
The comment you made about drilling out the alternator........ bracket to alternator is still tight. Bracket to engine came loose.
#362 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 19 July 2017 - 09:02 AM
My truck left me stranded for the first time last night. It seems to be getting no power to anything I can't turn on the headlights the car won't start not even so much as a click from the ignition. I know there is got to be a loose connection somewhere in the harness. Everything looks to be connected and nothing has been changed since it was driving fine. I'm thinking the culprit is somewhere within the fuse box? It might be time to upgrade to a more modern fuse box. I remember reading on flat cats thread about the blue sea systems fuse box and might go that route. But first I need to get my truck running and And home
#363 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 5,255 posts
  • Cars:71 Datsun 510 and 65 Mustang Fastback
Posted 19 July 2017 - 09:57 AM
Have U cleaned the fuse box?
#364 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 19 July 2017 - 10:03 AM
I'm bringing out my test light my multi meter some extra wire and I will grab some electrical cleaner and see if that does the trick. It was too dark last night to try to clean it so I'll get it figured out tonight hopefully
#365 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,428 posts
Posted 20 July 2017 - 04:54 AM
theres a wire from the battery positive that feeds the fuse box also. plus the one at the starter.
The proplem is at the fuse box. this has happen to me a couple times . I just pull the light switch then fuck move shit around the fuse box area then if light come on then you know your at the right spot.
Fuses might look good but swap them out anyways as they can breack at the ends inside and you cant see it.
this is a simple fix most likely
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
#366 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 21 July 2017 - 05:53 AM
It just needed a good cleaning in the terminals back on the road now.
#367 d.p
d.p
  • Senior Member
  • PipPipPipPip
  • 1,158 posts
  • Cars:1971 521, 2018 M3
Posted 21 July 2017 - 07:18 AM
Thats cool when it is something that easy.
#368 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 5,255 posts
Posted 21 July 2017 - 08:09 AM
You mean battery terminals or fuse area
#369 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 21 July 2017 - 02:18 PM
Fuse block had some corrosion on the terminals and the wire going to the coil from the fuses was very brittle. Coil wire wasn't the problem but could lead to another issue so I put in a new wire
#370 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 5,255 posts
Posted 22 July 2017 - 06:23 AM
Good u found the issues. Yeh our cars r like 40 years old and corrosion will b der
#371 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,237 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 22 July 2017 - 08:31 AM
I spray old fuse blocks with Purple Power to get rid of corrosion. If that's not enough, you could always hit it with a spray of metal prep. Don't let it sit on there too long though...
#372 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 19 April 2018 - 06:02 AM
Just bought a 72 510 for $500. Pics to follow once I pick it up tonight. Still driving my truck. Hope all is well with everyone and their projects. Haven't posted in quite a while
#373 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 19 April 2018 - 10:57 PM
7F3F0405-5A13-4B06-808A-241EF4DC20A9_zps
My new ride
#374 mrbigtanker
mrbigtanker
    Hall Monitor
  • Senior Member
  • 12,164 posts
  • Cars:Trailblazer ss/72 521/71 goon/454 SS/2016 canyon
Posted 19 April 2018 - 11:18 PM
What a photbucket sign. Help us out.
#375 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 20 April 2018 - 05:19 AM
Are there's other apps that share photos. PhotoFuckit
#376 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 20 April 2018 - 05:24 AM
#377 DanielC
DanielC
  • Senior Member
  • PipPipPipPipPip
  • 4,773 posts
Posted 20 April 2018 - 09:50 AM
I set up a website with GoDaddy.com.   Then you also have to rent server space, but that space is yours, and you control it.
I use a free FTP (File Transfer Protocall), program, Filezilla, to transfer images from my computer to the server space.
With the FTP program, you can transfer a single picture, a directory of pictures, or more.
After you have your pictures uploaded to the server, go to the Ratsun post you want to add pictures to.  Then you open a second window, or tab, and type in the full address of the picture you want in the Ratsun post, on your server.  Get the picture you want displayed in the second tab.
Go back to the ratsun post you are editing, and when you get to where you want the picture, click on the image icon in the second tool bar.  It is a green square, a bit of red on the bottom, with a blue outline.  That opens a small window in the Ratsun post, asking for an image url.  Switch tabs to your picture, highlight the full address in the location bar, and copy it, (control-C).  Switch back to Ratsun tab, with the small window.  Enter the picture address, (control-V).  That should post your picture, from your server.
#378 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 21 April 2018 - 09:22 PM
https://m.facebook.c...496&ref=m_notif
This is a link to face book. Not sure if it's accessible from here.
#379 Datsunthug
Datsunthug
    Advanced Member
  • Members
  • PipPipPip
  • 278 posts
Posted 21 April 2018 - 09:32 PM
https://m.facebook.c...t=group_comment
#380 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,428 posts
Posted 23 April 2018 - 05:21 AM
Oh dude I love it .
I would just buff it out and roll it as a Ratsun, the same color maybe lower it and get some wheels
