heywier427 Posted February 4, 2016 Report Share Posted February 4, 2016 I would like to know what stops the tach at 8k. Is it a little pin that can be moved, or is it something more not so easily modified. My rev limiter on my rotary is 9600 on trailing and 9800 on leading, and do not want an after market tach. I rigged up my shift light to come on at 9200 and it lights up the parking brake light. Its not really a big deal, but if I can simply bend a tab out of the way, that would be worth while. Thanks. 1 Quote Link to comment
KoHeartsGPA Posted February 4, 2016 Report Share Posted February 4, 2016 I wouldn't tamper with an oem tach....they aren't easy to come by and expensive when you do find one... Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 Thank you for your concern. Its exactly the reason I am not dissembling mine without further understanding it. I know the older members have either, a: taken apart and fixed tachs before. b: have a broken one laying around. So Im hoping the answer is readily available. I had mine apart when I swapped faceplates, and am confident in my abilities to tinker with delicate stuff. I just put the car/interior back together, and I really dont feel like digging back in if its not simple :) Anyone else? 1 Quote Link to comment
Draker Posted February 4, 2016 Report Share Posted February 4, 2016 Maybe this will do something for you? http://community.ratsun.net/topic/3689-fix-a-stock-510-tach/ Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 Yeah, I saw that while searching for tach pictures on the google. Not enough to make decisions on. I dont know why I didnt think of checking this when I wired in the shift light. I'll give this thread a day or so, then dive on in! Really want to get my front bumper prepped/painted installed this weekend. We'll see how fast the paint decides to dry :) Thanks. Quote Link to comment
MicroMachinery Posted February 4, 2016 Report Share Posted February 4, 2016 I rigged up my shift light to come on at 9200 and it lights up the parking brake light. How are you supposed to know when you leave your ebrake on, then? Sounds like a disaster waiting to happen; I'd use the oil light instead. 2 Quote Link to comment
KoHeartsGPA Posted February 4, 2016 Report Share Posted February 4, 2016 You disable the ebrake....duh! Quote Link to comment
MicroMachinery Posted February 4, 2016 Report Share Posted February 4, 2016 You disable the ebrake....duh! 2 Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 The ebrake light still functions as normal. I simply tapped the wires into the shift light wires. Use the oil light instead huh... So when shifting at 9500k, I want my oil light to come on... talk about making someone shit bricks!!!! Thats a very dumb idea. I was going to use the charge light, but I was worried about sending a signal through it while the car was running and charging. May do something funky to the regulator. The ebrake is top and center and has been replaced by a super bright led. I left the standard bulbs in the other dummy lights so the led purposely yells out at me, SHIFT ASSH0LE, SHIFT!!!!! :) 1 Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 How did I know I was opening up a trolling session :) :) :) 2 Quote Link to comment
KoHeartsGPA Posted February 4, 2016 Report Share Posted February 4, 2016 There are very reliable and nice looking aftermarket lights that will work without having to compromise an existing circuit in use.... Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 post up a picture of a clean/acceptable way to mount it, in plain sight. Acceptable to an anal perfectionist :) Taping in to a 12v light bulb, with a 12v signal for a fraction of a second does not compromise anything. I dont even know how you can write that. You cray cray. 1 Quote Link to comment
KoHeartsGPA Posted February 4, 2016 Report Share Posted February 4, 2016 No, use google, do the work, get creative. 1 Quote Link to comment
heywier427 Posted February 4, 2016 Author Report Share Posted February 4, 2016 I am not some glue sniffing wacko hacking away at my stock wiring. Go through some of my posts and look at the quality of my work. It is all professionally done, as I am a professional, with my own shop. Im going to check on my paint :) 2 Quote Link to comment
KoHeartsGPA Posted February 4, 2016 Report Share Posted February 4, 2016 You asked a question, I gave an answer.....some trolling (aimed at Micro's question)...and some opinion that resulted in you getting butthurt..... Quote Link to comment
MicroMachinery Posted February 5, 2016 Report Share Posted February 5, 2016 ...and some opinion that resulted in you getting butthurt..... I think he took it rather well, actually :lol: 2 Quote Link to comment
Lockleaf Posted February 5, 2016 Report Share Posted February 5, 2016 Seriously KOH, how does tapping one signal wire to one light "compromise a circuit". Even if there was a wierd reversion in the wiring, a single diode would fix it. Using an existing light is clever, and even if he just cut it clean, oh no he's lost his ebrake light..... Heywier took it fine, you seem to be the one having an issue with the whole thing 1 Quote Link to comment
KoHeartsGPA Posted February 5, 2016 Report Share Posted February 5, 2016 I used the wrong word, yes compromise wasn't right since there's nothing that can be harmed...so I guess the word should've been....not conflict either.....Damnit.....not sure what word could replace that...., what I ment is he should leave the light for its original purpose and simply add one for his shifting pleasure... Quote Link to comment
heywier427 Posted February 5, 2016 Author Report Share Posted February 5, 2016 shifting pleasure :) mmmmmm.....No one here is butt hurt :)All points are taken/valid.I will open up the tach sunday.Thanks for all the on topic non-trollagy.Deuces./ :rofl: 1 Quote Link to comment
q-tip Posted February 5, 2016 Report Share Posted February 5, 2016 Here is a pic of my shift light mounted, I used one of the screws for the metal part of the dash. I have to cut the mounting bracket for the light down to fin in the pocket for the screw but it mounted up nice. 1 Quote Link to comment
heywier427 Posted February 6, 2016 Author Report Share Posted February 6, 2016 That is just way to fuction>form for my anal ass! But thats why my customers love me. I always go for whats called OEM+, or steath, sleeper, ect... This car is way too nice, and Im making it more of an abuseable show car if that makes sense. My interior thus far: IMG_1239[1] by thomas telesco, on Flickr 1 Quote Link to comment
KoHeartsGPA Posted February 6, 2016 Report Share Posted February 6, 2016 Ooooh sooooo sexxxxy :thumbup: Quote Link to comment
q-tip Posted February 6, 2016 Report Share Posted February 6, 2016 Do all of the auxiliary guages and the stock guages work? Quote Link to comment
heywier427 Posted February 6, 2016 Author Report Share Posted February 6, 2016 Yes. All gauges and lights work as they should. Boost gauge is used for vacuum, as boost has not come yet :) But it will! Oh it will :) From left to righ, top to bottom: Water temp, oil pres, oil temp, Volts, egt, boost, afr. Egt is because the extreme heat of the rotary + turbo. Normal egt's of 1400-2000 deg. !! Just getting ready for the future :) Quote Link to comment
q-tip Posted February 7, 2016 Report Share Posted February 7, 2016 I'm assuming.in they're all electronic, no analog? Quote Link to comment
