Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 I need help getting the timing right on my engine, I can get it started then after I turn it off it wont start back up again I've tried about almost everything I've seen on the internet 1 Quote Link to comment
datzenmike Posted January 31, 2016 Report Share Posted January 31, 2016 12 degrees BTDC. Failure to re-start can be a lot of things... 2 Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 Could it be that my carb is getting to much gas so its flooding it and it idles really high 1 Quote Link to comment
KoHeartsGPA Posted January 31, 2016 Report Share Posted January 31, 2016 Did you check for spark and strength of it?, are plugs wet or dry? 1 Quote Link to comment
flatcat19 Posted January 31, 2016 Report Share Posted January 31, 2016 Do you own a timing light? Do you own feeler guages? Is your chain set properly? Have you removed the distributor recently? What did you do that, all of a sudden, caused a change in condition? 2 Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 The spark strength is pretty good The plugs are sometimes a tiny bit wet but mostly dry I don't own a timing light but I will borrow one from a friend Yes I own feeler gages and I gaped my points I'm pretty sure the chain is set properly and yes I have removed the distributor a few times I bought it in the condition that it's in 1 Quote Link to comment
distributorguy Posted January 31, 2016 Report Share Posted January 31, 2016 Hard start warm means too rich. Hard start cold too lean. Find the happy place in the middle. Quote Link to comment
datzenmike Posted January 31, 2016 Report Share Posted January 31, 2016 Could it be that my carb is getting to much gas so its flooding it and it idles really high Take the air filter top off and look when the engine is warmed up. Is the choke plate closed or partly closed like this... ...or open like this... 1 Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 I don't have an air filter on it And it doesn't get warmed up because I can't get it started But I'm really leaning towards the carb on this one Quote Link to comment
flatcat19 Posted January 31, 2016 Report Share Posted January 31, 2016 Where in Washington do you live? I'm sure you can get some help from a local. We're all over the place. Quote Link to comment
datzenmike Posted January 31, 2016 Report Share Posted January 31, 2016 I need help getting the timing right on my engine, I can get it started then after I turn it off it wont start back up again I've tried about almost everything I've seen on the internet I don't have an air filter on it And it doesn't get warmed up because I can't get it started But I'm really leaning towards the carb on this one You said trouble re-starting. So start it up when cold and drive around till warm and have a look. (and compare to my pictures) Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 I'm in mt vernon And when I start it up it has a really loud vacuum line and it idles really high Quote Link to comment
banzai510(hainz) Posted January 31, 2016 Report Share Posted January 31, 2016 And it doesn't get warmed up because I can't get it started???? WTF give us exact info. if it starts it has to get warm. Or does it die then don't restart. We are not there .Tell us everything. exactly. take photos of the motor and dist and coil set up. maybe choke stays on throw us a bone here Oh BUY a timming light don't borrow one and a mutimeter and test light 2 Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 I'm sorry lol It starts and then dies maybe a minute after and then I can't get it started back up I'm just going to borrow a timing light because I'm not looking to spend $300 on something I won't really ever use And I don't know how to post pictures on here Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 My choke is broken so maybe it is stuck open! Quote Link to comment
datzenmike Posted January 31, 2016 Report Share Posted January 31, 2016 Take the air filter top off and look when the engine is warmed up. Is the choke plate closed or partly closed like this... ...or open like this... Maybe??? Take a look right now hot or cold an compare to the pictures I posted. Open, Closed ??? Quote Link to comment
Guest 77ratsun Posted January 31, 2016 Report Share Posted January 31, 2016 It's closed on my carb Quote Link to comment
KoHeartsGPA Posted January 31, 2016 Report Share Posted January 31, 2016 Spring broken?, or if it's electric choke make solenoid is bad? Quote Link to comment
Guest 77ratsun Posted February 1, 2016 Report Share Posted February 1, 2016 Yes the spring is broken 1 Quote Link to comment
KoHeartsGPA Posted February 1, 2016 Report Share Posted February 1, 2016 Should be simple fix. Quote Link to comment
Guest 77ratsun Posted February 1, 2016 Report Share Posted February 1, 2016 The firing order on an l20b is 1342 right? Quote Link to comment
distributorguy Posted February 1, 2016 Report Share Posted February 1, 2016 Counterclockwise, but that doesn't fix the flooding that a stuck choke causes. Why do you ask for advice and not take it? 2 Quote Link to comment
datzenmike Posted February 1, 2016 Report Share Posted February 1, 2016 The choke coil holds it closed. If broken the choke would be open. You need the choke for starting and running in cold weather but it should warm up and shut off in 10 min or so. If the choke stays on or part on when the engine is warmed up you'll flood and it will be hard to re-start. 1 Quote Link to comment
banzai510(hainz) Posted February 1, 2016 Report Share Posted February 1, 2016 when cold choke falp is closed when you start truck there is a wire to the carb that heats up a coil spring an thus opens the flap to let more air in as it warms. make sure you have the wire that goes to the carb. timming lights are not 300$ I give them away Quote Link to comment
