Baillie Posted January 26, 2016 Report Share Posted January 26, 2016 Hi all, so I am considering putting a vn 3.6l engine into my 180B. The purpose behind it, is to do skids. sooo, I am new to engine swaps, and am curious to know what Ill need to make this happen. I can get the engine and box, complete cheap. I know Ill have to cut the Trans Tunnel, make engine mounts etc.. Has anyone done this swap yet? How will I go about the pedals, the driveline, the axels etc..? Any information would be helpful! Thanks! - Baillie. Quote Link to comment
datzenmike Posted January 26, 2016 Report Share Posted January 26, 2016 This is not a wise choice to make for someone who is asking how to do it. It ends up being a bigger job than first thought and the vehicle is ruined and sold off or scrapped. What is a VN 3.6? Quote Link to comment
thisismatt Posted January 26, 2016 Report Share Posted January 26, 2016 aussie holden/gm motor I'm guessing... 1 Quote Link to comment
Ratwagon1600 Posted January 26, 2016 Report Share Posted January 26, 2016 VN was the first of the Aussie Holden V6 engined "commodore" series. First produced here in 1988, the motors on average here now have in excess of 300k kilometeres on them and no one in their right mind would think of using one without a rebuild. They are also prone to blowing up coil packs. Later model "v" series Commodores (mid 2000's) with a V6 can be had in my neck of the woods for as little as $300. Very popular as a doner drivetrain for engine swaps. Anyway, RW thinks OP is definitely over their head with this one and there is a 180B (610) that sounds like its destined for the scrappers IMLTHO. Quote Link to comment
Ratwagon1600 Posted January 26, 2016 Report Share Posted January 26, 2016 Idjut. FIFY Mike. 1 Quote Link to comment
bananahamuck Posted January 26, 2016 Report Share Posted January 26, 2016 The use of the phrase , "Do skids" is the biggest tip off it is from there. From my research,, it should also be followed by a twirling of index fingers on both hands,, pointing at each other. 1 Quote Link to comment
paradime Posted January 26, 2016 Report Share Posted January 26, 2016 I can't add anything in the way of first hand knowledge, but with a swap this unique, you're likely on your own. Just because you can get the VN cheap doesn't make it a good idea. If you're spending an ass load of time and money hacking a cheap overkill engine into your Datsun, you're shooting yourself in the foot. Especially if you're "new to engine swaps". There are much better choices within reach, such as a KA 2.4L that will skid your 180B all round the outback. Quote Link to comment
scooter Posted January 27, 2016 Report Share Posted January 27, 2016 +1 for the ka... Are rwd ka's common in oz? If not maybe like a ca18det or sr20 where its well documented and theres aftermarket support for it? If its your first one buy the sr crossmember from datsport and a red top with trans and put er in... Some assembly required. Unless you have guidance from someone whos done it before or you have fabrication skills.... Your best to buy a whole running car with your donor drivetrain in it, so you have everything. But then again your probibly just another drift yahoo ruining all the good vintage sheet metal for everyone else that appreciates them. Quote Link to comment
Ratwagon1600 Posted January 27, 2016 Report Share Posted January 27, 2016 But then again your probibly just another drift yahoo ruining all the good vintage sheet metal for everyone else that appreciates them. ^^^^^^^^^^ This ^^^^^^^^^ Scooter, if the OP has hit puberty, ill be amazed! Quote Link to comment
scooter Posted January 27, 2016 Report Share Posted January 27, 2016 Ive seen wayy too many good cars go for scrap cause kids are trying to "wall tap" Quote Link to comment
paradime Posted January 27, 2016 Report Share Posted January 27, 2016 Another one post wonder. Quote Link to comment
