Profile Posted January 22, 2016 Report Share Posted January 22, 2016 What is the largest tire you can run on a 13 x 8 or 15 x 8 wheel with out stretching the tire? Thanks for your help. Quote Link to comment
Lockleaf Posted January 22, 2016 Report Share Posted January 22, 2016 Not sure I understand your question. Largest and stretching don't usually get put in the same sentence. You looking for old school drag muscle stance, with tires wider than the rims? 1 Quote Link to comment
TENDRIL Posted January 23, 2016 Report Share Posted January 23, 2016 i think a 225,215,205 would be what you are looking for, as far as side wall i wouldn't know Quote Link to comment
datzenmike Posted January 23, 2016 Report Share Posted January 23, 2016 What is the largest tire you can run on a 13 x 8 or 15 x 8 wheel with out stretching the tire? Thanks for your help. Define 'largest'. Tallest, widest, or the tallest widest? Define 'stretching'. Is a 7" wide tire on an 8" rim stretched??? Is 6"?? A 265/80R13 is 29.69" tall and 10.43 wide at the tread. A 160/40R13 is 18" tall and 6.3" wide at the tread. If the rim is 8" wide you can run tires with tread about 8" wide. A 205/40R13 is 8" wide at tread A 205/40R15 is 8" wide at tread. Here... https://www.rimsntires.com/specspro.jsp mess around with this and see if you find something you like. Quote Link to comment
Profile Posted January 23, 2016 Author Report Share Posted January 23, 2016 Thanks Mike! Quote Link to comment
datzenmike Posted January 23, 2016 Report Share Posted January 23, 2016 No problem. You know best what you want. Quote Link to comment
