Draker Posted January 21, 2016 Report Share Posted January 21, 2016 That just might be your fuel sender or gauge.. So the bafel design should be the same? On my 69, it was the same as a 71. Not sure about 68.. but i'd assume it's just like the 69. The tanks are a little different. my 69 tank had a small breather and no evap emissions like the later style. Quote Link to comment
Anonymous Waffle Posted January 21, 2016 Author Report Share Posted January 21, 2016 The tanks are a little different. my 69 tank had a small breather and no evap emissions like the later style. I don't think emission crap would do much besides vapors... Im curious if my pickup tube could be bent inside as well? But its weird since I've ran my old carb setup to the outside of the E mark, and had no issues... I'll post if something happens again. Quote Link to comment
Draker Posted January 21, 2016 Report Share Posted January 21, 2016 Yeah, the vent styles wouldn't matter. It's something dumb.. you'll find it. Quote Link to comment
Anonymous Waffle Posted January 30, 2016 Author Report Share Posted January 30, 2016 Drained the fuel tank, again. Just a note, we have drained and washed the shit out of the tank before... But more shit was in it... Found the culprit... or more so a family of culprits. Yep. Geckos. Or lizards. Whatever the hell they are. Quote Link to comment
bilzbobaggins Posted January 30, 2016 Report Share Posted January 30, 2016 :sick: 1 Quote Link to comment
datzenmike Posted January 30, 2016 Report Share Posted January 30, 2016 Anyone ever have fuel delivery issues when you get less than a quarter tank of fuel? Roughly 3 gallons. Had it starve the carbs once, and wasn't a clog, after getting more fuel, it started up. Do different years have different fuel tank designs? I'm running a l16, stock fuel pump, su carbs. Won't be carbs or fuel filter... how the hell do either know the tank is getting near 3 gallons every time??????????? Unless you empty out the remaining gas how you know there's 2 or 3 gallons left??? Maybe the gauge float is bent down and you really did run out of gas. The float bottoms on the empty tank bottom but the gauge still reads 2-3 gallons. Stock 510 is 11.9 US gallons. Next time it 'runs out' refill and subtract this amount from 11.9. Take the sender out and compare the amount of drop when held outside the tank. Bend up to suit. If it actually does run out with 2-3 gallons left in tank this is easily explained by the pick up tube being bent. Any amount of bend will raise the end up and away from the vertical leaving more gas inaccessible. This could be caused by a PO using a piece of chain shaken inside the tank to loosen rust when cleaning it. Remove the tank and take the sender out and look in the hole with a flashlight. Suction tube should be near bottom of tank. Quote Link to comment
Anonymous Waffle Posted January 30, 2016 Author Report Share Posted January 30, 2016 Won't be carbs or fuel filter... how the hell do either know the tank is getting near 3 gallons every time??????????? Unless you empty out the remaining gas how you know there's 2 or 3 gallons left??? Maybe the gauge float is bent down and you really did run out of gas. The float bottoms on the empty tank bottom but the gauge still reads 2-3 gallons. Stock 510 is 11.9 US gallons. Next time it 'runs out' refill and subtract this amount from 11.9. Take the sender out and compare the amount of drop when held outside the tank. Bend up to suit. If it actually does run out with 2-3 gallons left in tank this is easily explained by the pick up tube being bent. Any amount of bend will raise the end up and away from the vertical leaving more gas inaccessible. This could be caused by a PO using a piece of chain shaken inside the tank to loosen rust when cleaning it. Remove the tank and take the sender out and look in the hole with a flashlight. Suction tube should be near bottom of tank. Do simple math... 12.1 11 7/8 gallons, run the car to a certain level, lets say less than a quarter tank, fill the tank up all the way, then subtract the amount you filled up from 12.1 11 7/8 gal. So if we filled up 8.5 gallons... thats 2.4 gallons, give or take in the tank.. :yawn: :yawn: :yawn: :yawn: :yawn: :yawn: :yawn: Quote Link to comment
Anonymous Waffle Posted January 30, 2016 Author Report Share Posted January 30, 2016 If it actually does run out with 2-3 gallons left in tank this is easily explained by the pick up tube being bent. Any amount of bend will raise the end up and away from the vertical leaving more gas inaccessible. This could be caused by a PO using a piece of chain shaken inside the tank to loosen rust when cleaning it. Remove the tank and take the sender out and look in the hole with a flashlight. Suction tube should be near bottom of tank. Only reason why it always had fuel delivery issues, was when the fuel level was low, it started sucking up the crap that we found in the tank. Quote Link to comment
Stoffregen Motorsports Posted January 31, 2016 Report Share Posted January 31, 2016 The stock fuel tank does have a bad pickup design. When cornering hard, anything less than 1/4 tank is a problem. When I used to race SCCA in a 510, we would always calculate enough fuel to compensate for this issue. Quote Link to comment
