76_620 Posted January 16, 2016 Report Share Posted January 16, 2016 I have a 1973 510 sedan, what transmissions can I use that bolt right on ? Quote Link to comment
datzenmike Posted January 17, 2016 Report Share Posted January 17, 2016 A 26" long L series 3N71B automatic or an F4W63 L series 4 speed. The 510 ones work best. 2 Quote Link to comment
76_620 Posted January 17, 2016 Author Report Share Posted January 17, 2016 Will a 280zx 5spd bolt on ? Quote Link to comment
datsunaholic Posted January 17, 2016 Report Share Posted January 17, 2016 To the engine, yes. To everything else, no. Driveshaft, mount, speedo cable, floor of car need mods for that. Quote Link to comment
Stoffregen Motorsports Posted January 17, 2016 Report Share Posted January 17, 2016 ...but, a 280zx 5 spd swap is one of the easiest mechanical conversions known to man. You can buy a fabricated steel crossmember, the floor needs almost nothing, a massage at best, the cable...who needs a speedo anyway, and the drivehsaft can be modified at your local driveline shop for $100. Quote Link to comment
datzenmike Posted January 17, 2016 Report Share Posted January 17, 2016 My 710 has the same length and speedometer location 4 speed as the 510. I put a 71B long 5 speed in and just un-clipped the original short cable from the body and ran it down behind the head and diagonally over the top of the transmission and hooked it up. Works just fine and have three or so trips to Canby or 5-6K miles on it. Driveshaft needs to be shortened to 37 3/8" long for the sedan. Trans mount? Have a friend make these up for you and you can use your stock crossmember and rubber mount. . 2 Quote Link to comment
datsunaholic Posted January 17, 2016 Report Share Posted January 17, 2016 OK, so I amend it- It's a "Bolt on" IF you have all the right custom pieces made. Geez. To me, "Bolt On" means, take out old trans, put in new, with no custom fabricated parts being used. All parts "off the shelf" or from the donor car or recipient. No drills, no welding, no tin snips, no sawzall. I don't even consider the dogleg to be a "bolt in" and that needs one part modified. 3 Quote Link to comment
datzenmike Posted January 17, 2016 Report Share Posted January 17, 2016 Doug, only saying that the cable will fit if you re-route it. You still need to mod the mount and driveshaft as you said. Maybe even trim the shifter hole? Yes the dogleg is close to 'bolt in'. 1 Quote Link to comment
Stoffregen Motorsports Posted January 17, 2016 Report Share Posted January 17, 2016 My point was that you shouldn't limit yourself in life to things that bolt on. If we all did that, we'd all be driving Jeeps! Armed with a little knowledge, a set of jackstands and an afternoon, this trans swap can be done easily. Think ahead and bring the driveline in on a Thursday to have it for the weekend. 2 Quote Link to comment
davev55 Posted January 18, 2016 Report Share Posted January 18, 2016 So out of curiosity, what does the dogleg take to "bolt in"? Quote Link to comment
datzenmike Posted January 18, 2016 Report Share Posted January 18, 2016 Only the mount needs 'work'. See my last post. Those mods work for the 71B and the 63A dogleg. See the second paragraph in the article. If you go with the 63A dogleg keep your present release bearing collar and put it on the dogleg clutch arm. (use a new bearing though) 1 Quote Link to comment
banzai510(hainz) Posted January 27, 2016 Report Share Posted January 27, 2016 techno toy tunning has a X memebers for sale also 1 Quote Link to comment
