mcordero8 Posted March 27, 2017 Report Share Posted March 27, 2017 It might be a vacuum leak. Spray some carb cleaner around the base of the carb, and if it accelerates you have a vacuum leak. Just put a new gasket and you should be fine. Quote Link to comment
NoMoneyZ Posted March 27, 2017 Author Report Share Posted March 27, 2017 whats timming again? It's set at 10. Quote Link to comment
NoMoneyZ Posted March 27, 2017 Author Report Share Posted March 27, 2017 It might be a vacuum leak. Spray some carb cleaner around the base of the carb, and if it accelerates you have a vacuum leak. Just put a new gasket and you should be fine. All gaskets are new. I sprayed around after I installed the carb and nothing changed. Quote Link to comment
