EBW Posted December 10, 2015 Author Report Share Posted December 10, 2015 I am Curious what Brand and weight Oil you guys are running ?? And.. are guys running a winter vs summer Weight ?? 2 Quote Link to comment
banzai510(hainz) Posted December 11, 2015 Report Share Posted December 11, 2015 any brand 10-30 10-40 winter summer 20-50 15-40 Summer 30wt works also. if still even around 3 Quote Link to comment
distributorguy Posted December 11, 2015 Report Share Posted December 11, 2015 Pick your oil weight based on outdoor temps. Brand preference? That's up to you. 3 Quote Link to comment
EBW Posted December 11, 2015 Author Report Share Posted December 11, 2015 Hit a speed bump cleaning the Weber. The Power Valve Diaphragm "gasket" was damaged while carefully being dissasembled. Did I mention the Carb was GUMMED up !! Come to find out the rebuild kit doesn't have that part due to it NOT needing replaced. Great !! Now to try and find one that isn't in Australia, the UK, or Germany. This is an internet picture. The gasket on mine is that paper material and was damaged. Weber Power Valve Diaphragm 57804.052 #14 on the exploded Weber Diagram 2 Quote Link to comment
datzenmike Posted December 11, 2015 Report Share Posted December 11, 2015 I am Curious what Brand and weight Oil you guys are running ?? And.. are guys running a winter vs summer Weight ?? Every year the ZDDP level in oil is being lowered because ALL cars made in the last 20? years use a roller rocker cam that does not need the extra scuff protection afforded by the 'high' zinc levels. Probably it gums up the fancy new tech catalytic converters, eventually it all ends up in the environment. Everyone assures us that the level was extra high to begin with and reducing by almost half does no harm to older 'flat tappet' engines. I don't know if this is true or not but I do know that I won't be trusting my valve train to some 'expert' oil company geek. To this end I run 15W40 Shell Rotella T (15W40 Chevron Delo 400 is similar) This is a 'light' diesel oil that still retains the old level of ZDDP in it that our old Datsuns were designed to run on. It's a bit more detergent so it gets darker sooner, but the engine does stay clean. 15W40 shouldn't be a problem for California winters 3 Quote Link to comment
EBW Posted December 11, 2015 Author Report Share Posted December 11, 2015 Thanks for the info Mike, exactly what I was looking for. And I live in Diesel country, so Rotella is a common Oil here. Funny you mentioned the Zinc. I built a Stroker motor for a project a few years ago and I was in the same situation. The type of motor uses a 30W oil. Well, come to find out even those weights were low on Zinc. I ended up using Briggs and Stratten 30 Weight oil that had the proper Zinc. If you would have told me I was going to build an expensive motor and put Lawnmower Oil in it, I would have called you crazy ! 2 Quote Link to comment
datzenmike Posted December 11, 2015 Report Share Posted December 11, 2015 Valvoline GTX and others make a 'racing' oil with lots in it. Go to NAPA and ask for a flat tappet oil for chevys, they know what you mean. 2 Quote Link to comment
gene knight Posted December 13, 2015 Report Share Posted December 13, 2015 EBW: welcome to ratsun. pm sent if you need any parts or steel wheels let me know I have a plethora of 620 parts pcd: no 2 Quote Link to comment
distributorguy Posted December 13, 2015 Report Share Posted December 13, 2015 The Weber power valve is available as a replacement part, with gasket. Contact Pierce Manifolds. 3 Quote Link to comment
EBW Posted December 15, 2015 Author Report Share Posted December 15, 2015 Will get some pictures up of the progress soon.... Currently still waiting on the last bit of parts before attempting to turn over engine for the first time. While I am waiting... Question to the forum. Lowering Blocks 3" or 4" Angled or straight Looking to be lowered but not slammed. Running stock steelies with the white walls. I have both sets ready to buy but am waiting to see what you guys suggest. 2 Quote Link to comment
Charlie69 Posted December 15, 2015 Report Share Posted December 15, 2015 If you are going to use blocks adjust your rear brakes before installing. Angled to maintain correct pinion angle. Height of block is your choice. 2 Quote Link to comment
sebpv Posted December 15, 2015 Report Share Posted December 15, 2015 I have 4in but cant show u until I get the body back on... 3 Quote Link to comment
EBW Posted December 16, 2015 Author Report Share Posted December 16, 2015 Took the shell off. Already looks better ! 1 Quote Link to comment
EBW Posted December 16, 2015 Author Report Share Posted December 16, 2015 Parts are starting to arrive.... 1 Quote Link to comment
EBW Posted December 16, 2015 Author Report Share Posted December 16, 2015 Thanks to Daniel aka dhp123166 for selling me 73 rims and hubcaps. Going to blast them and get them ready for paint. Then tires. 1 Quote Link to comment
EBW Posted December 16, 2015 Author Report Share Posted December 16, 2015 Got rid of the Old carpet and plywood underneath. Bed is surprisingly in good shape. 2 Quote Link to comment
sebpv Posted December 16, 2015 Report Share Posted December 16, 2015 Scrub it clean and if you're aiming for function: Bedliner it 3 Quote Link to comment
EBW Posted December 16, 2015 Author Report Share Posted December 16, 2015 Scrub it clean and if you're aiming for function: Bedliner it Yep, bedliner is in the future. 2 Quote Link to comment
EBW Posted December 19, 2015 Author Report Share Posted December 19, 2015 Got all the new parts in, hoses replaced, fluids replaced, Carb rebuilt, etc...... Go to fire it up and it actually started !! Rough, but it did run. As I let it warm up, the carb idle started to increase and the engine was warming up nicely. I could start to hear a ticking sound, and was wondering if I had a stuck valve. Then all of a sudden pop. The carb is backfiring through what appears the cycle. Blown head gasket ?? Stuck valve ??? I will upload a video of the motor running. Curious what you guys think... and what my next course of actions should be..... ???? Did a compression check #1 125 #2 133 #3 135 #4 145 Here is a pic of the cleaned up motor. 2 Quote Link to comment
datzenmike Posted December 19, 2015 Report Share Posted December 19, 2015 Take valve cover off and look at the rockers where that meet the valve spring. You may have dropped a lash pad and the rocker popped off. Likely an exhaust. 4 Quote Link to comment
EBW Posted December 19, 2015 Author Report Share Posted December 19, 2015 Here is the video. The popping is a backfire coming out of Carb. Any suggestions ? I am checking what Mike suggested in the morning. http://vid220.photobucket.com/albums/dd156/Firecrusader/1973%20Datsun/DSCN1334_zpsvi5loja8.mp4 1 Quote Link to comment
banzai510(hainz) Posted December 19, 2015 Report Share Posted December 19, 2015 always ck the timming points condenser issue and make sure its the stock point and coil with ballast if still running points also loose distributor bushing. then ck the carb. 3 Quote Link to comment
distributorguy Posted December 22, 2015 Report Share Posted December 22, 2015 Carb backfire is usually timing that's too far advanced (intake valve still open when the distributor fires). Check which vac line the distributor vacuum advance is hooked to. Use the Weber port with no vacuum signal at idle. Try 10-12 BTDC at idle, vac line disconnected. 4 Quote Link to comment
EBW Posted December 22, 2015 Author Report Share Posted December 22, 2015 Thanks for the info Hainz and Distributorguy I checked the vacume on the Distributor ( manually) to make sure it worked, which it does. The vacume line is attached to the only part on the Carb that was open. ( Brass outlet nipple on the side facing the engine ) You can see it in the pic above. Is there another area that it is supposed to be connected to ?? I am missing it ?? Thanks again for all the help here !! You guys are awesome 2 Quote Link to comment
sebpv Posted December 22, 2015 Report Share Posted December 22, 2015 The vacuum line is correct. did u check the distributor pedestal for the timing as mentioned above? 3 Quote Link to comment
