Gradyfest Posted January 7, 2016 Author Report Share Posted January 7, 2016 Why do I keep logging in... Lol Link to comment
Gradyfest Posted January 7, 2016 Author Report Share Posted January 7, 2016 Gentleman, ladies, whatevers; I stand behind the filtering of coolant so much... I want to promote it: http://community.ratsun.net/topic/68264-coolant-filters/page-1 Every vehicles coolant system benefits from filtering. Link to comment
DanielC Posted January 7, 2016 Report Share Posted January 7, 2016 My first thought, U-joints. Second thought, a chipped tooth in the rear, or front axle. If four wheel drive, can you put it in four wheel, and drop the rear drive line to isolate the noise some. 1 Link to comment
Gradyfest Posted January 7, 2016 Author Report Share Posted January 7, 2016 I could disconnect the rear drive shaft and drive in four wheel drive for sure. I like it. I'm going to finally put the front end up off the frame and see how loose everything is as step one. 1 Link to comment
Rick-rat Posted January 7, 2016 Report Share Posted January 7, 2016 Could be a small piece of metal in one of the gearboxes or one of the differentials rattling around inside, Maybe you could put a filter on each one 3 Link to comment
KoHeartsGPA Posted January 8, 2016 Report Share Posted January 8, 2016 Did you check if the coolant filter has the paper inside?, might have gotten sucked in by the heavy centrifugal force of the water pump and the noise you hear is the sediment bouncing inside the filter housing..... Dunno Just a thought :poke: 1 Link to comment
Gradyfest Posted January 9, 2016 Author Report Share Posted January 9, 2016 Lol. You basterds! Now don't go getting all my threads padlocked gentleman. But there is nowhere else to talk about coolant filters now though... 1 Link to comment
KoHeartsGPA Posted January 9, 2016 Report Share Posted January 9, 2016 Yes there is and always will be, we call it INSOMNIACS an open forum to talk about anything and everything with no remorse! Link to comment
Gradyfest Posted January 9, 2016 Author Report Share Posted January 9, 2016 But coolant filters are technical and a great idea. Insomniacs however... What the hell good info can be found in there? Link to comment
Rick-rat Posted January 10, 2016 Report Share Posted January 10, 2016 So, is it fixed yet? If you spent as much time trying to fix it as you do trying to convince us to use coolant filters, it would be fixed by now :confused: :yawn: 3 Link to comment
KoHeartsGPA Posted January 10, 2016 Report Share Posted January 10, 2016 Good shot, Rick! :thumbup: :rofl: Link to comment
KoHeartsGPA Posted January 13, 2016 Report Share Posted January 13, 2016 Gradyfest, in case you haven't noticed....I'm advancing your agenda spreading it all over the forums as I see fit :thumbup: Link to comment
