DanielC Posted January 17, 2016 Report Share Posted January 17, 2016 Refer back to the electrical diagram I put on page one of this thread. There are four wires going to the alternator. A thick white wire, from the main positive output of the alternator. This wire goes to the starter, to the same terminal on the starter solenoid the positive battery cable connects to. The negative battery cable connects to the cylinder head, behind the a little below the fuel pump. There is a pigtail that goes down to the alternator frame. There is also a second black wire, that goes into the electrical harness. This wire goes to the voltage regulator, and is connected to one of the bolts that hold the voltage regulator to the inner fender. Both of these black grounding wires are very important. If the engine or the alternator loses a ground connection to the inner fender, or frame of the truck, the ground connection will be made through the throttle cable, overheating it, and destroying it. There are two small connections also on the alternator. Make sure those connections on the alternator are marked "F" and "N" The yellow wire goes to "N" The white wire with a black stripe goes to "F". You cannot put a jumper from the alternator to somewhere, because the alternator is externally regulated. It needs the four wires to connect to the voltage regulator. If you jump some wires around, and you get the alternator to work, it might be unregulated, and the alternator could put out way more than 12 volts. 1 Quote Link to comment
Jacobs601 Posted January 30, 2016 Author Report Share Posted January 30, 2016 My alternator is marked with an E and an A. What's up with that? 1 Quote Link to comment
Elkie Posted January 30, 2016 Report Share Posted January 30, 2016 E is sometimes used for earth or ground 1 Quote Link to comment
Jacobs601 Posted February 13, 2016 Author Report Share Posted February 13, 2016 Quote Link to comment
Jacobs601 Posted February 13, 2016 Author Report Share Posted February 13, 2016 2 Quote Link to comment
Jacobs601 Posted February 13, 2016 Author Report Share Posted February 13, 2016 1 Quote Link to comment
Jacobs601 Posted February 13, 2016 Author Report Share Posted February 13, 2016 Such a pretty day, I had to take a few "Glamour Shots" of my pride and joy 521. Enjoy. 1 Quote Link to comment
banzai510(hainz) Posted February 13, 2016 Report Share Posted February 13, 2016 dude I woild just lower it with 3 inch blcoks on back and drop the front up unscrewing the torsion bar nut(has a lock nut also) its the square looking lug till you almost run out of thread. I like the rust you got going on. find some stock rims and paint them white Maybe add some NGK stickers!!!!!!!!!!! 1 Quote Link to comment
Suplexilicious Posted April 4, 2017 Report Share Posted April 4, 2017 Both of those stickers are awesome! The truck looks great. Quote Link to comment
datzenmike Posted April 4, 2017 Report Share Posted April 4, 2017 Ok, so after the family trip, I decided to make one more trip by myself. I get almost home and my throttle sticks wide open. A little scary but I used my ignition kill and crank my way back. When I get it back in my shop I found this. This is where this spring should hold the throttle closed but somehow I guess the spring wore a hole through the hole in the linkage and came off. Guess I'll rig something up to hold it in there. Almost guarantee that is not the original spring. Probably just bought to replace a broken one and is too stiff. This will happen again. Quote Link to comment
