720 Radiator Support Rehab
DrvnDrvr
I'm starting a rehab of my radiator support and would like to find a way to permanently modify the cooling system to drain the coolant without having it drain on the front crossmember. Maybe putting a petcock on the lower radiator hose. Maybe an extension of the existing petcock. I'm trying to preserve the paint on the frame.
Any ideas?
  • Replies 7
IMG_20151001_133507637_zpsxo76yxh2_edit_
I installed an adapter and then a brass petcock. I freaking hate how they designed that. A 5/8 hose fits over the exposed threads and I just put that in to a bucket to drain it.
This is on my '85 720.
I will get you that info (as best I can remember it) later today. The thread adapter I used wasn't actually the correct thread, but it was "close enough". When I threaded it all the way in it would tighten up pretty well. Then, just to be sure, I gooped the threads with rtv in addition to putting a copper crush washer on it.
That was three years ago or so and it hasn't leaked a drop
Pretty sure it's a 3/8 to 1/4 "bushing" adapter.
I bought the stuff at O'Reilly Auto. Brand is edelmann. Adapter p/n is 210640. Petcock is p/n 349440. You will also need a hose barb or threaded coupler. They have a ton of options depending on how you want to do it.
My petcock threads are fine and a standard 1/4"  won't fit . I'm gonna see if the mechanic at work has a metric die to make a thread adapter. My O'Rielly didn't have the right one. The radiator is new so I don't want to rinkydink it up. Thanks for the input.
