wayno Posted December 4, 2015 Report Share Posted December 4, 2015 You know you need that cross member below the engine. 1 Quote Link to comment
Slickk1One Posted December 4, 2015 Author Report Share Posted December 4, 2015 I know Im in the process of building one out of tubing & bending it 1 Quote Link to comment
Slickk1One Posted December 14, 2015 Author Report Share Posted December 14, 2015 Okay so more pics will be updating got snow this weekend so hopefully next week is clear. Got some more ideas will be posting more pics. 1 Quote Link to comment
Slickk1One Posted December 14, 2015 Author Report Share Posted December 14, 2015 1 Quote Link to comment
Slickk1One Posted December 14, 2015 Author Report Share Posted December 14, 2015 Its going nice I also have started wiring & it is coming out Clean 1 Quote Link to comment
wayno Posted December 14, 2015 Report Share Posted December 14, 2015 The round headlight is wired different than the square headlight, so you cannot just plug in the headlights and expect they will work. Also the bright indicator light in the 521 dash will not likely work with the later harness, you will need to get a 2 wire plastic light socket that will fit in the 521 bright indicator hole, then use the two wires in the D21 harness to make it work, in the 521 the instrument cluster uses a ground to complete the circuit, in the 720 and likely the D21 there is no ground in the instrument cluster, and if you try to ground it out to make it work, nothing will work right, fact is that the headlights will start to faintly glow even though they are not on, email me and I will try to explain it better when you get to that point, I have done it 3 times now, and Charlie69 down by you has also done it. Its going nice I also have started wiring & it is coming out Clean Will be shorting the factory D21 column & using gearbox from D21. May cut & weld the factory 521 steering arm. May use heater core from D21 in 521 dash but mainly need to wire up dash. I want to run the original dash but of the D21 harnesses. This will be fun... 1 Quote Link to comment
Slickk1One Posted December 14, 2015 Author Report Share Posted December 14, 2015 Yea I have most the wiring already mounted. I need to take a Pic of it when thres light. Heres another 1 Quote Link to comment
flatcat19 Posted December 14, 2015 Report Share Posted December 14, 2015 Those wheels won't fit. Too much positive offset and I believe wrong bolt pattern. 1 Quote Link to comment
Slickk1One Posted December 15, 2015 Author Report Share Posted December 15, 2015 here's the new wheels 1 Quote Link to comment
greenthumb Posted December 15, 2015 Report Share Posted December 15, 2015 'photo not found' 1 Quote Link to comment
Slickk1One Posted December 15, 2015 Author Report Share Posted December 15, 2015 ??? I have it up now 1 Quote Link to comment
greenthumb Posted December 15, 2015 Report Share Posted December 15, 2015 Got it. How wide are those rims, and what offset? 1 Quote Link to comment
Slickk1One Posted December 15, 2015 Author Report Share Posted December 15, 2015 6 lug 5.5 inch or 139.7mm Medium Offset 1 Quote Link to comment
greenthumb Posted December 15, 2015 Report Share Posted December 15, 2015 are there numbers cast in the back of those wheels? That would be the offset in mm. If that bolt pattern fits, I can't see why they wouldn't clear despite the positive offset. Titans are 8 in wide with a pretty positive offset, and mine clear well 1 Quote Link to comment
