Busta Nut Posted November 17, 2015 Report Share Posted November 17, 2015 I need a catch can for 5Teezy.........wonderin what you guys are using.......... So if you got one installed.......would you mind posting pics?? I need some ideas........... Thx folks!! Quote Link to comment
datzenmike Posted November 18, 2015 Report Share Posted November 18, 2015 Why you need? Only required on some race courses to prevent spills from blown engines. Quote Link to comment
INDY510 Posted November 18, 2015 Report Share Posted November 18, 2015 because race car 3 Quote Link to comment
Skib Posted November 18, 2015 Report Share Posted November 18, 2015 Iv got a Greddy one, havent used it though, kinda big for my engine bay. Quote Link to comment
Laecaon Posted November 18, 2015 Report Share Posted November 18, 2015 Air compressor water/oil separator. Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 > Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 Why you need? Only required on some race courses to prevent spills from blown engines. ...........vv because race car .........and this.....vv Blow by. Last track day I came in hard on the last corner........ ..........smoked down the whole straight........ ..............I got flagged in...... :hmm: Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 Iv got a Greddy one, havent used it though, kinda big for my engine bay. Would it be big for a 510 engine bay?? .....got pics layin around?? Quote Link to comment
datzenmike Posted November 18, 2015 Report Share Posted November 18, 2015 ...........vv .........and this.....vv Last track day I came in hard on the last corner........ ..........smoked down the whole straight........ ..............I got flagged in...... :hmm: Catch can won't stop smoke. Get a baffled oil pan or windage tray. Better yet a dry sump. Quote Link to comment
Skib Posted November 18, 2015 Report Share Posted November 18, 2015 Would it be big for a 510 engine bay?? .....got pics layin around?? Prob not. Iv got all kinds of shit in my ZXt bay lol 3 Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 Thx skib...... Catch can won't stop smoke. Get a baffled oil pan or windage tray. Better yet a dry sump. My bad Mike.......I failed to mention that the oil blew out the PCV hole on the L20B........ ...........I don't even have the tube so the oil blew straight onto the header..... ..............hence the smoke..... Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 Air compressor water/oil separator. You lost me on this one....... Quote Link to comment
UnderControl Posted November 18, 2015 Report Share Posted November 18, 2015 Air compressor style air oil separator. I used to run one on my mustang until switching to a breather can. 3 Quote Link to comment
datzenmike Posted November 18, 2015 Report Share Posted November 18, 2015 Thx skib...... My bad Mike.......I failed to mention that the oil blew out the PCV hole on the L20B........ ...........I don't even have the tube so the oil blew straight onto the header..... ..............hence the smoke..... If not running a PCV, plug the lower block vent but keep the valve cover vent clear. Traveling to the top of the engine gives the oil droplets more time to stick to any surfaces and drip back into the pan. Again,a baffled oil pan will keep the oil contained around the pickup and prevent splashing the spinning crank, keeping the oil fog down. Gain a few hp too. A lower pan will help also if you have the clearance. If you can't go down widen the pan to the sides. Oil level will be lower but have the same amount in it. 2 Quote Link to comment
shacks510 Posted November 18, 2015 Report Share Posted November 18, 2015 Again, a baffled oil pan will keep the oil contained around the pickup and prevent splashing the spinning crank, keeping the oil fog down. Gain a few hp too. A lower pan will help also if you have the clearance. If you can't go down widen the pan to the sides. Oil level will be lower but have the same amount in it. Comp pans aren't cheap. A hefty $720, and a few month wait. Antony, don't you have a rebuilt 2.2? Why would it have so much blowby? 1 Quote Link to comment
Laecaon Posted November 18, 2015 Report Share Posted November 18, 2015 Catch cans are also great to stop the oil mist/condensation from building up in your intake and on the valves. I installed a catch can onto my BMW and actually reduced oil consumption. 2 Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 Comp pans aren't cheap. A hefty $720, and a few month wait. Antony, don't you have a rebuilt 2.2? Why would it have so much blowby? No idea.....only at really high RPMs....like redline high...... ........only happend the one time but it does still spit sometimes....just not enough to burn.... 2.2....closed chamber head and a mild cam..... Engine made it Oregon and back without burning a drop of oil...... 1 Quote Link to comment
Stoffregen Motorsports Posted November 18, 2015 Report Share Posted November 18, 2015 Here's one that I have made a handful of. I plumb to the valve cover breather and the block breather combined so whatever comes out of the valve cover can drain back into the block. It also has baffles a filter on top and a removable lid so you can clean it out. 5 Quote Link to comment
Busta Nut Posted November 18, 2015 Author Report Share Posted November 18, 2015 That is pretty sweet!!! :thumbup: Quote Link to comment
MantisX620 Posted November 18, 2015 Report Share Posted November 18, 2015 I have a moroso one I took off my turbo honda. Its plumbed to the PCV pipe and the top of the valve cover. I get some smoke out of the top of it at idle sometimes but driving it seems fine. I have to drain it maybe once every 2-3 months 2 Quote Link to comment
shacks510 Posted November 18, 2015 Report Share Posted November 18, 2015 Some kind of catch can has been on my mental list of things for when I get my 2.2 in. I would prefer to have it working as a PCV system, but it's a little harder with side drafts. I have Mikuni 44s with the Mikuni manifold; I know how I could make it so that it pulls air from all cylinders, but I haven't decided yet. I'll for sure do something so fumes don't blow into the wiper motor hole and gas me out like the L16 did :D 2 Quote Link to comment
Boxcar Posted December 10, 2015 Report Share Posted December 10, 2015 Try this . At 15.28 and free shipping why bother fabing one? http://www.ebay.com/itm/BILLET-ALUMINUM-RACING-ENGINE-OIL-CATCH-RESERVOIR-TANK-CAN-HOSE-INDICATOR-BLACK-/201249093731?hash=item2edb617863:g:jvcAAOSwMmBV4JEJ&vxp=mtr 1 Quote Link to comment
Laecaon Posted December 11, 2015 Report Share Posted December 11, 2015 Because that is a piece of crap with no filter and or trapping element in it. Its literally a can and two hoses. There is no swirling, no chambers to catch oil particles, nothing. Now if you know how to modify it, then maybe it can be ok. But really, just use an air compressor water/oil separator. 2 Quote Link to comment
Stoffregen Motorsports Posted December 11, 2015 Report Share Posted December 11, 2015 That's right. Why have a catch can if it's just going to breath oily mess into the engine bay. Baffle it at least. Mine are baffled, you can open them to clean them out, there's a filter on top, and if positioned properly in the engine bay, you can have them drain back into the block anything that gets puked into the can. Quote Link to comment
