itsallgood Posted November 13, 2015 Report Share Posted November 13, 2015 it seems to be really hard to find wheels for r trucks. that just bolt on. i am looking for a set that will not have to be milled and bolt right up. i have rotors on all for. the truck is on air so i was wondering what width of wheel i can run. so my wheels tuck in the fender? dose anyone know the exact center bore? can anyone tell me if these will fit, are they to wide or can i go wider? http://www.summitracing.com/parts/usw-70-7760 thanks for the help. Quote Link to comment
kelowg Posted November 14, 2015 Report Share Posted November 14, 2015 U need like 30-35mm +offset(fwd offset) maybe more or wheel spacer to clear. Front stock hubs have four tabs? 521's do, grinded those down to fit my old escalade wheels. Xterra nismo wheels tuck even with 1/4in spacers. But only 16x7. Quote Link to comment
datzenmike Posted November 14, 2015 Report Share Posted November 14, 2015 Correct. It isn't so much the rim/tire width, but what the rim setback is. I'm glad to see someone asking rather than buying rims and then trying to make them fit. Here try messing with this... https://www.rimsntires.com/specspro.jsp Take some measurements on your stock rims and how much fender clearance you have plug it in and try varying rim and tires 2 Quote Link to comment
itsallgood Posted November 17, 2015 Author Report Share Posted November 17, 2015 Correct. It isn't so much the rim/tire width, but what the rim setback is. I'm glad to see someone asking rather than buying rims and then trying to make them fit. Here try messing with this... https://www.rimsntires.com/specspro.jsp Take some measurements on your stock rims and how much fender clearance you have plug it in and try varying rim and tires so if i mount 18x10 wheels with the right offset will they stick out past the fender? that is what i don't want. Quote Link to comment
datzenmike Posted November 18, 2015 Report Share Posted November 18, 2015 I have no idea. Here try messing with this... https://www.rimsntires.com/specspro.jsp Take some measurements on your stock rims and how much fender clearance you have plug it in and try varying rim and tires Quote Link to comment
