jdub_one Posted November 5, 2015 Report Share Posted November 5, 2015 Would anyone share pics of their SR swap heater hoses? I have searched a bit and haven't found much. I can make a wire and go searching but if there was any other reference that would help me I would appreciate it.Thanks 1 Quote Link to comment
DrRocks0 Posted November 6, 2015 Report Share Posted November 6, 2015 I don't have pictures of mine anymore but I can walk you through it. I removed it because I don't need the heater in SoCal. Anyways there are 2 pipes coming under the intake manifold to the thermostat housing. The lower one I plumbed into the passenger side outlet, the upper one then made a 90 degree bend after the cylinder head and went to the driver side heater core outlet. Your turbo coolant inlet feed also comes from the part going behind the head. I removed that and made a fitting off the water neck. Hope this helps. Quote Link to comment
jdub_one Posted November 7, 2015 Author Report Share Posted November 7, 2015 It does. Thank you. I have an NA but it makes sense. The what where is helpful. Appreciated. Quote Link to comment
DrRocks0 Posted November 7, 2015 Report Share Posted November 7, 2015 It's a tight fit, try to get all the lines on the motor before you install it, working behind the head in front of the fire wall sucks. Quote Link to comment
