67 pl411 in the works
Bkplunk64
Not planning on parting it out, the only thing I have taken off is the wiper motor to clean but found out that a piece was broken in the arm assembly, looked to be a brittle copper ot bronze notched washer type piece. May be on the market for a new motor
Not sure about the copper thing you're describing but instead of buying "new to you motor"  just take your wiper motor into a shop that rebuilds electric motors,,,  Pumkin Dave says there is a very good ( and cheap)  rebuild shop in Puyallup.
here is a motor off of Ebay in Oregon.
early
http://www.ebay.com/itm/EARLY-1966-DATSUN-411-BLUEBIRD-ELECTRIC-WINDSHIELD-WIPER-MOTOR-REMAN-JIDECO-OEM-/391182158578?hash=item5b14460af2:g:lVQAAOSwu4BVizzd&vxp=mtr
Late ,,, same seller
http://www.ebay.com/itm/1966-1967-DATSUN-411-BLUEBIRD-ELECTRIC-WINDSHIELD-WIPER-MOTOR-REMANUFACTURED-OEM-/371361775323?hash=item5676e2fedb:g:i8MAAOSw9N1Viz1q&vxp=mtr
  • Replies 44
  • 1 month later...
If anyone sees this in time and is anywhere close to the tacoma, wa area I have a set of horns, 3 hub caps, a rear bumper for 67 411.
When are you leaving i could come tomorrow , How much for bumper ??
Are you going south I5??  i could meet up along the route
  • 1 month later...
I need to know the proper placement of the condenser, and wiring, I'm burning my points and I'm going to start with a new condenser
There's a clockwise wire leading from the points plate to a black plastic feedthrough on the side of the distributor.  On the outside, you will see a push-on connector for the point ground wire.  Loosen the screw,install the capacitor lead and retighten.  The capacitor has a ground lug with a hole in it.  Bolt this lug to the side of the lower distributor housing, there's a tapped hole for it.
Side item, the ground lead at the distributor is a good theft protection device.  Unplug it and hide it in the wiring harness.  Car won't start without a ground at the points!  Much less obvious that pulling the rotor.
  • 2 months later...
