ABS plastic door panels- question
saw a cool and great idea someone did to there z, they used abs plastic to make door panels out of so i thought id give it a shot. But i purchased the panels and asked the guy if he could cut them to the correct shape, he said he could but it would be 250$ now im no plastic cutter but that seams outrageous to me so me question is. What is the best way to cut ABS plastic? or if anyone's done this before what steps they took? i can add pics if needed
thanks
  • Replies 15
Avoid anything that abrades to cut. These tools will generate friction and melt their way through the plastic.
Jig-saw
If the cutting teeth on a jig-saw are too widely spaced (course) it will grab too much and can chip or start a crack. Too fine will not clear the teeth of cut plastic and it will just grind away and heat up enough to melt and then you really are in trouble. Try different tooth count blades on a piece of scrap first to get the best cut. The plastic must be securely held down so it doesn't begin osculating from the blade cutting. Masking tape the surface and draw lines on it to keep the cut straighter. Take your time to prevent heat
Skill-saw
For long straight cuts use a skillsaw with the blade in backwards. (Or a 200 tooth specialty blade for plastic)
This prevents the teeth grabbing on the down cut and basically 'grinds' it's way along but works well enough if you take your time and is faster than a jig-saw.
Hi There,
New guy with a question.
I would like to make some ABS door/kick panels for my Roadster (a 1968 1600), but, don't know where to purchase the ABS sheets.
Any suggestions on places that sell the ABS sheets at a decent price?
Thanks,
  • 2 weeks later...
Hi There,
Thanks,
Tap Plastics  in San Jose, California    Good people great service.
