Anyone remove windows?
  • Replies 7
Not hard at all. take the seals out from the top of the door runners pop panel off and the rest is pretty self taught once you see what to do.
There is a clip on the back side of the track at the bottom of the glass that holds the glass to the regulator. You need to remove that clip but you can't see it. If you put the window most of the way up, you can reach you hand around and grab the clip and pull it off. Once you have done this, you can separate the window from the regulator and lift the glass out through the upper opening. It helps to remove the outer window stainless strip.
These pics should help.
C0F45A04-9539-42E3-AD67-23A103F25896_zps
7B9837F2-857D-4B0B-A96A-306E25D39BAD_zps
4FE7710D-5012-49AC-83A0-BB2DD239F1FE_zps
This is on a 510. Not sure on others.
