KdotGong521 Posted November 1, 2015 Author Report Share Posted November 1, 2015 Does this seem like a potential problem i need to change out (the crack on the coil.) I bought a accel coil but took it back because i want to run a msd setup. 1 Quote Link to comment
DanielC Posted November 1, 2015 Report Share Posted November 1, 2015 The crack in the coil probably is going to be a problem. You would be much better off getting a stock matchbox Nissan distributor, and coil. 1 Quote Link to comment
banzai510(hainz) Posted November 2, 2015 Report Share Posted November 2, 2015 where you get that fuel pump? you know if you still have points or run a POINT coil you still need a ballast resisitor. what kind of alternator is that ? Its not stock as I can tell from a later nissan. I assume the volt reg connector has the jumpers also 1 Quote Link to comment
KdotGong521 Posted November 3, 2015 Author Report Share Posted November 3, 2015 Im not sure Banzai, The motor came this way. So i need a ballast resistor ? I really wanna go Electronic distributor with a Msd setup. If anybody got a dizzy, Pm me.. Whats the jumpers for ? Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 So today i got the titans back from the tire shop and couldnt wait to jack her up & slep em on for a test fit. I have just been trying to find a good welder to get my 4-link and step notch welded in. I got one quote from a shop down here in S.D. and they want a grip to weld link and notch the truck so if anybody out here want to put down some nice welds for me, let me know. I need to get some rear disc squared away out back with new hoses running to the front next. In the mean time, I need to replace my wheel studs with a new set I recieved from the Rock. Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 They need to be plastidipped. Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 Rear view Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 Heres where a question to the suspension fabricators of the crew comes in, I plan to build my truck to tow a small jet boat in the summer to Laughlin and occasional camping trips. I have a mini camper also so Bag behind axle or Bag on link bar ? Im assuming bag behind axel like the truckers. Quote Link to comment
KdotGong521 Posted November 4, 2015 Author Report Share Posted November 4, 2015 Better pic of air ride parts already gotten. I just gotta find somebody that can get down. Quote Link to comment
hobospyder Posted November 4, 2015 Report Share Posted November 4, 2015 The tire with the sticker showing is on backwards. What are the rims you pulled off? 1 Quote Link to comment
KdotGong521 Posted November 23, 2015 Author Report Share Posted November 23, 2015 Today i got a chance to get back on it a bit. I started working on the extended lugs for the from Rock A. I only got so far due to not having the right tools, gotta work on my tool game !! I just threw gunk parts from my rear ends to clean, see how the purp stuff from parts store works to degrease.. Quote Link to comment
KdotGong521 Posted November 23, 2015 Author Report Share Posted November 23, 2015 Quote Link to comment
KdotGong521 Posted November 23, 2015 Author Report Share Posted November 23, 2015 I wanna go with the disc rear end, so i will loose most of this I think anyway. I know fellow Ratsunerz have kits for the disc setup, Im on tha hunt.. Quote Link to comment
