Kytoaster Posted September 23, 2015 Report Share Posted September 23, 2015 Well, this is definitely something I've never heard of, and I've spent a fair amount of time tinkering with/fixing cars.I changed all the fluids yesterday (Oh lord, the rear diff and gear oil on my 620....lets just not talk about it), and used a vacuum bleeder to bleed the brakes. All seemed well, until I hit the brakes, and the pedal was surprisingly not hard. I started the truck to see if the booster might help...and HOOOOLLY SMOKE!!!!!Smoke EVERYWHERE!!! Only, it wasn't oil, I could smell brake fluid when the smoke hit me. Has this happened to anyone else?I've got a lot of experience with automotive repair, but nothing older than mid 80's.If brake fluid is really getting into my engine, I feel like having a hydrophobic fluid inside my engine is going to wreak absolute havock on my seals, and no telling what it could do to the internals... Quote Link to comment
banzai510(hainz) Posted September 23, 2015 Report Share Posted September 23, 2015 if power brakes the diaprhame can have a hole and sucking in brake fluid. Seen this on a Volvo P1800. Thought was head gasket at first. We were stumped as we didnt know where the brake fluid was going. disconnected the vaccum line to the brake booster and see if still smokes. this is my 1st guess 1 Quote Link to comment
datzenmike Posted September 26, 2015 Report Share Posted September 26, 2015 You would have to have a failed master also to pass fluid to the rear past the push rod into the booster. Brake fluid isn't going to harm anything, in small amounts. It is safe on rubber or any other synthetic 'rubber' like urethane, neoprene... Likely spilled brake fluid on the exhaust burning off. Quote Link to comment
