guyster Posted September 16, 2015 Report Share Posted September 16, 2015 I've lowered my spring perch 2" from it's original position. I did not shorten the strut tube. (Should I have done that? Is it OK that I didn't?) I need to replace the struts, so for an uncut tube, do I simply replace the struts with stock size? If I bite the bullet and break it all down to cut the strut tube, then do I buy shorter struts? FWIW, I'll be using bump steer spacers. Thanks! Quote Link to comment
Draker Posted September 16, 2015 Report Share Posted September 16, 2015 I did the same thing as you. No issues. When I raise the car, the wheels droop off of the spring perches a bit.. if I had shorter inserts, this wouldn't happen.. not really an issue. 1 Quote Link to comment
thisismatt Posted September 16, 2015 Report Share Posted September 16, 2015 By doing so you've cut your suspension up travel by 2", so you will bottom out much more easily. If you cut the tubes you will regain some travel. Quote Link to comment
Draker Posted September 16, 2015 Report Share Posted September 16, 2015 By doing so you've cut your suspension up travel by 2", so you will bottom out much more easily. If you cut the tubes you will regain some travel. Actually yes, I did have this issue. I just raised it up a little bit. I have about 1/2" gap from tire to fender with 195/50/15s and I don't bottom out. Smaller tires would make it worse. Quote Link to comment
Draker Posted September 17, 2015 Report Share Posted September 17, 2015 To add to that last statement.. I also have 250lb springs up front. It rides a little stiff with the L20 up front. I think 200lbs springs would be more comfortable.. but as a result I would probably bottom out again and need to shorten the struts. 1 Quote Link to comment
guyster Posted September 17, 2015 Author Report Share Posted September 17, 2015 To add to that last statement.. I also have 250lb springs up front. It rides a little stiff with the L20 up front. I think 200lbs springs would be more comfortable.. but as a result I would probably bottom out again and need to shorten the struts. Well, this will be interesting as I have the L20, too. I'm using stock coil springs, uncut. Just dropped the spring perch 2". I also will be running 13" Libres with a somewhat low profile tire (50 series, I think, don't have them in front of me.) The rear will have D50s with one coil cut can Camero shocks - I did not slot the crossmember. All in all, I think the car will have a little rake. Which I'm hoping looks good. I'm worried about the small wheel / tire setup now, though. UPDATE: My tires are 155/65R13 and not 50 series. 1 Quote Link to comment
banzai510(hainz) Posted September 17, 2015 Report Share Posted September 17, 2015 just be careful you dont lower that so much it hit the top of the tire. als the offse issue if you want to run a better looking rim 13 Libras and low profile = a car screaming at 60mph 1 Quote Link to comment
guyster Posted September 17, 2015 Author Report Share Posted September 17, 2015 13 Libras and low profile + a car screaming at 60mph I hear you!! According to Dime Quarterly, the rear drop should be less than 2", and the front is currently set at 2", then the L20 may drop the front a little more. I did the split collar for the front, so I can raise the front if need be. I may do a bigger rim / tire setup, eventually - along with the 280ZX strut/brake setup. I bought these Libres and invested in repair, powdercoat and paint, so now I feel obligated to run them. We'll see. If the set up would work better with a taller tire, I may just bite the bullet and invest in some Hoosier high profile 13s (http://goo.gl/DM01Au) Quote Link to comment
KoHeartsGPA Posted February 23, 2016 Report Share Posted February 23, 2016 Revival for a quick question...where can I source the clamps to place below the perch? Quote Link to comment
guyster Posted February 23, 2016 Author Report Share Posted February 23, 2016 Revival for a quick question...where can I source the clamps to place below the perch? Here you go: https://www.fastenal.com/products/details/34405 1 Quote Link to comment
KoHeartsGPA Posted February 23, 2016 Report Share Posted February 23, 2016 Thank you, I'll order up! Quote Link to comment
Draker Posted February 23, 2016 Report Share Posted February 23, 2016 Thank you, I'll order up! Eugene fastener has these in stock. That's where I got mine. Price is about the same. 1 Quote Link to comment
KoHeartsGPA Posted February 23, 2016 Report Share Posted February 23, 2016 :thumbup: Quote Link to comment
RJRACIN240 Posted May 9, 2016 Report Share Posted May 9, 2016 I hear you!! According to Dime Quarterly, the rear drop should be less than 2", and the front is currently set at 2", then the L20 may drop the front a little more. I did the split collar for the front, so I can raise the front if need be. I may do a bigger rim / tire setup, eventually - along with the 280ZX strut/brake setup. I bought these Libres and invested in repair, powdercoat and paint, so now I feel obligated to run them. We'll see. If the set up would work better with a taller tire, I may just bite the bullet and invest in some Hoosier high profile13s (http://goo.gl/DM01Au) Have the impression you are building a street car, would be careful buying the Hoosier rains....think they would not hold up well for days when there is not a rain! 1 Quote Link to comment
