anyone running SUMITOMO tires?
btd19m
http://sumitomotyres.com/
got to run light truck tires for rego or get it engineered for normal tires in aus on a 720. and same with the 4x4. shes on steel at the moment.
shes got 15's up front and 16's in the back. anyone running similar on a 4x4? no idea why the old owner did it.
  • Replies 5
Rims size doesn't matter much, it's the tire size used on the rims. A 215/75R15 tire is 27.70" diameter, a 205/80R14 is 27.72" Same but different rims. Larger tires can often improve mileage by acting like a lower ratio differential but the odometer will now be off and it will be difficult to figure out. You will have traveled farther but it won't show.
