IvyRacer Posted September 6, 2015 Report Share Posted September 6, 2015 Were you able to pass smog with a Webber Carb? If so, please share. 1 Quote Link to comment
cruznude Posted September 7, 2015 Report Share Posted September 7, 2015 only with a good friend that works as a smog technician and likes some extra green, 2 Quote Link to comment
kelowg Posted September 7, 2015 Report Share Posted September 7, 2015 Yep, no way to pass. Unless smog tech doesnt look under air cleaner 1 Quote Link to comment
TFM1066 Posted September 7, 2015 Report Share Posted September 7, 2015 Call weber and see if they have a C.A.R.B number 2 Quote Link to comment
datzenmike Posted September 7, 2015 Report Share Posted September 7, 2015 There used to be a weber 32/34 that was legal. Or used to be. 1 Quote Link to comment
datsunaholic Posted September 7, 2015 Report Share Posted September 7, 2015 32/34 DFT, which was a much smaller carb, smaller than the DGV. But was a bolt-on match, no adapter needed for the manifold.. Long NLA, though- at least 15 years. And it would have to have the correct CARB tag, with the right number for the application (not just any 32/34 DFT would work, even if it had a tag, it would have to be the exact tag number for the vehicle model). But, the CARB exemption allowing the Weber 32/34 DFT9 (or DFT11) only covers 720s through '82. As far as I can see 83+ have no allowance for anything other than the original Hitachi. 1 Quote Link to comment
Stoffregen Motorsports Posted September 7, 2015 Report Share Posted September 7, 2015 My brother had a 620 back in the 80's and his had a smog legal Weber on it. It passed no problem. I know that kit is no longer available. The carb itself was from a Fiat or Ford (2.3?) I can't remember. I did a quick search for "Ford OEM Weber carb" and came up with some promising results. On the web, they are calling it a Holley 5200. There are a ton of them on ebay. 1 Quote Link to comment
Stoffregen Motorsports Posted September 7, 2015 Report Share Posted September 7, 2015 Fiat - http://www.ebay.com/sch/sis.html?_nkw=FIAT%20124%20131%20CARBURETOR%20EMPI%2032%2036%20DFEV%20WEBER%20CLONE&_itemId=280664719221 Ford - http://www.ebay.com/bhp/ford-pinto-carburetor 2 Quote Link to comment
IvyRacer Posted September 9, 2015 Author Report Share Posted September 9, 2015 I have an '84 720 z24 so it sounds like those won't work for me. So, it seems like my options are to tear into my "functioning" carburetor, and open myself up to a seemingly endless new li$t of parts I'll have buy to fix the d*** thing (assuming I can put it together correctly), or skip the headache and buy a brand new CA legal hitachi for $4-500. Even then, there might be more problems that I haven't narrowed it down to yet, like the cat, o2 sensor, egr, etc... or maybe my motor is bad and this is all futile. Crap. 1 Quote Link to comment
DanielC Posted September 9, 2015 Report Share Posted September 9, 2015 "Even then, there might be more problems that I haven't narrowed it down to yet, like the cat, o2 sensor, egr, etc... or maybe my motor is bad and this is all futile." When you do a tune up, you do all that and more (adjust valves) before you even think about touching the carb. A lot of "carb:" problems are actually problems with ignition, or other issues. 4 Quote Link to comment
Gradyfest Posted September 10, 2015 Report Share Posted September 10, 2015 Exactly, make touching the carburetor the last thing you do for a smog certificate. I once took off a catalytic converter and soaked it in dish soap with water over night once (with intermediate shaking,) and let it air dry for two days to pass. But it worked! Button up exhaust and all emissions first. 2 Quote Link to comment
Gradyfest Posted September 10, 2015 Report Share Posted September 10, 2015 Well, back to the point; You have a Weber... Ignore my previous post. :/ 1 Quote Link to comment
IvyRacer Posted September 10, 2015 Author Report Share Posted September 10, 2015 I have a stock carburetor, and it is leaking air at the base, as well as fuel from... somewhere. Looks like one of the body seals is seeping. 1 Quote Link to comment
Gradyfest Posted September 10, 2015 Report Share Posted September 10, 2015 They make rebuild kits you can buy from parts stores on the cheap with full instructions, I think. That with the search bar and datzunmike here, it'll take time and be a learning process; but worth it for sure. Pass it then throw the Weber on if you want. 2 Quote Link to comment
84720FourWheel Posted September 10, 2015 Report Share Posted September 10, 2015 I've heard that putting a bit of ethyl alcohol in the tank helps as well. I'd research that a bit more. 1 Quote Link to comment
Stoffregen Motorsports Posted September 11, 2015 Report Share Posted September 11, 2015 I have an '84 720 z24 so it sounds like those won't work for me. Why wouldn't that work for you? One thing you could do is get a Weber with a fuel shutoff solenoid and electric choke. Use the factory Nissan wiring pigtail to wire them both. Do as clean an install as possible with the throttle linkage and all the right vacuum lines, and get the DGV air cleaner adapter adapter (or modify the OEM air cleaner to fit) so when the tech opens the hood, it looks all stock. I have heard of cases where the guy doesn't even look at the carb. Point is, if it looks stock, he may be fooled into thinking it is stock. 2 Quote Link to comment
poopypants720 Posted January 30, 2016 Report Share Posted January 30, 2016 Has to Fiat - http://www.ebay.com/sch/sis.html?_nkw=FIAT%20124%20131%20CARBURETOR%20EMPI%2032%2036%20DFEV%20WEBER%20CLONE&_itemId=280664719221 Ford - http://www.ebay.com/bhp/ford-pinto-carburetor Has to be the 32/34 dft9a and its stamped on the base of the carb. Contrary to some reports I've heard, this is MUCH better than the stock Hitachi In power and very easily tuned when jetted correctly to both pass smog and then retuned to perform very nicely even with 32" tires... Takes a little(k , bout 15°) advance, 91 octane and and a good "best idling lean adjustment" then turned one turn back rich... Rebuild kits for gaskets are cheap on ebay and I've even seen 2 on ebay going for around 130-150, one used and one "old stock, New in box"... I'll be keeping mine to kill smog tests, then getting a 38 to swap out n get a better throttle response while wheeling. 1 Quote Link to comment
cruznude Posted January 30, 2016 Report Share Posted January 30, 2016 I just found out a little bit ago that they dropped the smog requirements here in New Mexico to anything under 1980 dont have to get smog tested. Hooray for my 79 kc 620................ 1 Quote Link to comment
