Mattndew76 Posted September 10, 2015 Report Share Posted September 10, 2015 Go trailing link with some FOA's PLEASE!!!! Long travel D-Goon is bad ass!! Subscribed! 2 Quote Link to comment
DaBlist Posted September 10, 2015 Report Share Posted September 10, 2015 Tires? Sand Paddles strapped to the roof rack to throw on the rear then you get there. 3 Quote Link to comment
Abe Froman Posted September 10, 2015 Report Share Posted September 10, 2015 Did you just go with lift blocks on the rear? The easy way would be an axle flip, to flip the axle from over leaf to under the leaf spring. 2 Quote Link to comment
hobospyder Posted September 10, 2015 Report Share Posted September 10, 2015 The easy way would be an axle flip, to flip the axle from over leaf to under the leaf spring. that's what he said he was going to do in post 2 or 3 I think. Just before he started with the pictures of the cutting 1 Quote Link to comment
hobospyder Posted September 10, 2015 Report Share Posted September 10, 2015 Blackdeth I love that you lowered the truck and are raising the car. I need to stop by and meet you sometime, you still work at that tattoo shop that I've seen the truck at? 2 Quote Link to comment
Bob3 Posted September 11, 2015 Report Share Posted September 11, 2015 Okay, this is cool, subscribed! :thumbup: 2 Quote Link to comment
dukerollo Posted September 11, 2015 Report Share Posted September 11, 2015 The easy way would be an axle flip, to flip the axle from over leaf to under the leaf spring. Right, otherwise they would be lowering blocks. I have 3" blocks on mine and axle wrap was a problem. I'm curious if blackdeath had to use any blocks to get the lift he desired and if so how will spring wrap be combatted. 1 Quote Link to comment
blackdeth666 Posted October 8, 2015 Author Report Share Posted October 8, 2015 Decisions, decisions. About the motor... L16 or KA? I was told the L16 ran, but have never heard for myself. I cleaned up and redid the gaskets on the stock L16, and put a new clutch behind it and also adjusted valves. I did a compression test and it had good and even compression so I dont see why it wouldnt run. I would just need to rebuild the stock carb, or, I do have a weber on the shelf that I could use, but that is also questionable if it needs rebuilding. I have heard webers are very simple. This is currently in the car. I came up on a KA24de full swap (motor, wiring harness, ecu) a little while back when my buddy went SR on his 240sx. I know this motor runs, it was his daily. Unknown mileage. Would also be pretty cool in my 521. Since the wagon project is experimental at this stage, I wonder if I want to go through the extra cost and trouble of doing a motor swap, maybe only to find out its frightening to drive! Then I also wonder If i'll go through equal amount of hell trying to get this old L motor running... I have never put an EFI motor in anything and something about getting it all wired/hooked up intimidates me. The KA would also allow me to potentially run power steering since the pump is still there but I'd have to source the rack. about the tires... 27x8.5 14 I was very limited on selection 14" all terrains. It was between these and BFG. These were cheaper so that made the decision easy. http://s1205.photobucket.com/user/datrat666/media/IMG_5955.jpg.html 2 Quote Link to comment
TENDRIL Posted October 8, 2015 Report Share Posted October 8, 2015 as your attorney, i advise a ka to move those wheels 4 Quote Link to comment
Farmer Joe Posted October 8, 2015 Report Share Posted October 8, 2015 i think the l16 will move it just fine... at least to drive it. swap a 3rd member from a truck in it with some 437s... it would move just fine then.. just have to swap the side spider gears from the 510 3rd member to the truck 3rd member. this is getting interesting... 3 Quote Link to comment
INDY510 Posted October 8, 2015 Report Share Posted October 8, 2015 A front sump oil pan, like the S13/S14 KA24DE, would make a rack and pinion swap easier ... :poke: ... like an MR2 rack 1 Quote Link to comment
Draker Posted October 8, 2015 Report Share Posted October 8, 2015 as your attorney, i advise a ka to move those wheels Classic! Rip 3 Quote Link to comment
Abe Froman Posted October 8, 2015 Report Share Posted October 8, 2015 Those wood floors in your shop are just sooooooo cool ! 3 Quote Link to comment
blackdeth666 Posted October 14, 2015 Author Report Share Posted October 14, 2015 The test fit.... It is just the look I was hoping for! Ready to terrorize the neighborhood. Making a little clearance now.... Here's a guy I know, think his name is Aaron with a KA swap and went with rack and pinion. I think This might be the answer. I am in the process of fabricating new LCA's thare are 1.5" to 2" longer. It will widen the front track with a bit and correct the positive camber issue I inherited with the lift. I should have more progress on that to come soon! 7 Quote Link to comment
TENDRIL Posted October 14, 2015 Report Share Posted October 14, 2015 god dammit..........this thing is soooo rad!! 1 Quote Link to comment
Draker Posted October 14, 2015 Report Share Posted October 14, 2015 Indeed... indeed, it is. 1 Quote Link to comment
hacked521 Posted October 27, 2015 Report Share Posted October 27, 2015 Thats so badass!!! 1 Quote Link to comment
fisch Posted October 27, 2015 Report Share Posted October 27, 2015 Subscribed. Kick ass work. 1 Quote Link to comment
DaBlist Posted June 6, 2016 Report Share Posted June 6, 2016 Up for sale at good price https://seattle.craigslist.org/sno/cto/5615895743.html 1 Quote Link to comment
dukerollo Posted June 6, 2016 Report Share Posted June 6, 2016 Here I was all excited for an update... 1 Quote Link to comment
kneesamo Posted June 6, 2016 Report Share Posted June 6, 2016 This is bitchin'! 1 Quote Link to comment
fisch Posted June 7, 2016 Report Share Posted June 7, 2016 Aww man sad not to see this thing get finished in Blackdeth666's hands. One of the builds here I was most interested in. Did you grab any shots of the axle flip in the rear? Quote Link to comment
banzai510(hainz) Posted June 8, 2016 Report Share Posted June 8, 2016 another 510 going to the scrapper, pretty straight also would have been done just put the L motor and lower it ,1month job if that Quote Link to comment
