toyota 4 ac single cam....fuel in oil after revving to 4000 rpm
ok so while i take a break from the datsun, i tinker on the old corolla
4ac with 5speed
car sat for ten years with gas from when bush was president
i got the car bout a year ago
only ran on brake cleaner
took to a shop to blow compressed air in gas tank
fuel was so caustic it smelled like varnish with jack daniels
s got it to run finally only to have a fuel in oil issue...super rich fumes, and dumped so much raw gas into converter it glowed
not sure if seals on valves went bad, another guy saying bad rings, but if i drive the car over 50mph, fuel gets in the oil
tracking down this problem is hard other than the fuel pump itself which i replaced  3 times, also new filter cuz paper dissolved in old one
mechanical fuel pump supposedly has oil seal
is the caustic fuel eating the diaphram inside the pump?
bad valve seats or lash?
timing belt and sprockets line up, although hard to start cold
no real drivability issues until i drive on hwy.
drive for like a week and it will have a quart of fuel in the oil, lol
worst case i will pull the motor for a good spare i have but want to learn something or resolve this motor issue
have carb and head to spare also if that would alleviate
need old timer to chime in
  • Replies 14
doesnt seem to burn oil....although it smokes but fuel fills up the pan
havent done a compression test or re-lash
rings idk.....i would know since the datsun has bad rings and was a quart a day drinker
valve guides or seals i would suspect just from sitting ten years with old fluids....clutch master would just randomly leak also
I don't think bad valve seals would let fuel in the oil. You'd be burning oil before fuel was able to get up through the seal. I say bad rings. Put your hand over the breather tube on the block (I'm guessing the 4AC has one) and feel how much air is coming out. Does it smell like gas? Bad fuel pump diaphragm sounds likely too.
If the gas is that bad it is defiitely not completely burning ,, so there is so much unburned gas in cylinder that it is washing past rings..
I don't understand why the "shop" blew compressed air into tank??  Why would you/ they not just take tank off and dump old shit gas out and do the obvious,,,,,,,,,,,,,, and just ,,,,,,,,,,,put new gas in???
And lastly,,  how many times have you changed the oil since trying to get this running??
Carb could be flooding. Drips into intake after shut off and finds way past the rings then or when starting. Probably hard to start and runs like shit on every start up till it clears. A couple of teaspoonfuls of gas every start up soon adds up to a quart in the oil pan. After shut off take the air filter off and take a look... see gas dripping? Is there a window on the front of the carb? any way to check the float level? Needle valve stuck or something stuck in the needle valve that it won't close all the way?b
If pump was replaced then not pump
eye burning fumes under hood and under car.....would idle and smell like mikes hard lemonade and boones farm with a spritz of pinesol
the breather gave me trouble when i put an orielly's mini filter on it. ran way worse and would make hard to start
yes it is a pain to start even with starter fluid, even at operating temp (new battery)   alt is charging
took air cleaner off entirely, which had a hose going to carb and pcv
if i put my finger on the pcv hose end, idle drops
no blowby really
carb has a tiny float bowl but its way out of tune. mixtures are jacked and it has all kinds of linkages and vacuums,...
good thing is that i doesnt stall, does fine on street, at light,  but  idles 1200 rpm without air cleaner .... until the dilution starts
i want to just switch it with a spare i have or pull motor altogether n replace with known good runner from wreckd parts car
gas light would come on constantly after getting on hwy, ....read the manual and it mentioned 02 reset
so there is a weird o2 sensor reset button under the dash by brake pedal...have already replaced 02 but may try that again
i reset that switch then also the emissions computer and canister from good runner ( idk desperate to see if makes a difference)
now no smoke or fumes or dilution but i havent hit the hwy yet
huge wasp nest under head light...they like fumes i guess
well i got the car to the shop and it would only run on brake fluid and a jump start box,  so  a mechanic suggested blowing air into gas tank to clear lines i guess
ran under its own power/ fuel source
should have drained tank instead of trying top burn bad gas out
guess i hurt the motor
compression is pretty even on all four ....150 psi or around 11.5 to 12 kg/cms
plugs arent oily
havent checked timing cuz distributor bolt stripped but pulled timing cover...belt ok, cam n gear dots aligned
revvs hard like two a15s  combined and doesnt miss until 4000rpm on hwy/ dilution
sounds like its boosted at that point....vroom, bpp,bpp,bpp,bpp,bpp then dies
sit on shoulder for 30 minutes til it turns over then limp home with intermittent stalling
  • 4 weeks later...
ok in vain trying to fix fuel issue
switch to spare carb from junkyard from motor they said ran
before i checked lash i pulled valve cover and it was just gas in the head
i soaked up as much as i could...free motor flush
cam and rocker were dry, some scratches on lobes
i ran it for a second with valve cover off to see if gas was shooting out fuel pump but oil came up so fast and sprayed everywhere
im used to ohv datsuns where i can lash with no valve cover cuz oil takes a second to flow out rockers
oil pressure was up immediately as opposed to before oil pressure only after revving...low idle oil pressure with other carb which concerned me. some people saying lifters. i was worried oil pump bad, but guess so diluted
i can let idle long time, no dilution...also had harness and emission computer unplugged...idk if that affects floats/ vacuum etc
but if i rev over 3000, something in carb is wrong
before too much gas
now too little
drove down hill and revved to 4000 rpm
gas didnt dilute right away but only drove down street 5 min. usually after 20 mins it acts up with original carb.
started easy and pulled hard but it stalled out by time i hit 5th gear.  popped hood.  float glass empty so i primed carb with a lil gas from filter
got home and quit for the day
at this point i want to remove all emission parts n computer, go aftermarket carb to rule out that part of system so i can focus on mechanical pump or gas tank
