GoGoGo Posted August 16, 2015 Report Share Posted August 16, 2015 So in trying to get my speedometer to work I've already replaced the speedo cable (new Pioneer one) plus tried another good used one and it's clear that something in the sending unit is not working. It's way to hot right now to get under the car and pull out the unit so I'm just seeing if anyone has had some experience with either the unit or pinion gear breaking/not working. If the sending unit is broken what other unit with bolt right in? The only other one I have is going to be from a 1971 510 auto so I have no idea if that will bolt in? What about the pinion gear in it? Sorry for all the questions but I am a planner by nature and career so like to know the possible next steps before they even have to happen. :confused: Quote Link to comment
flatcat19 Posted August 16, 2015 Report Share Posted August 16, 2015 You need a speedo pinion that matches your rear end. Use that to help you search. This was just answered, again, a couple of days ago. Quote Link to comment
datzenmike Posted August 16, 2015 Report Share Posted August 16, 2015 Speedometer not working... Lots of unknowns and assumptions here. Lets narrow this down some.... Disconnect the speedometer cable at the transmission. Have someone watch the speedometer while you twist the inner cable with your fingers. Clockwise I think but try both directions. Does the speedometer even move?? NO....... stop right there, you've found the problem. Inner cable may be broken, the dash end is not inside the speedometer head or the speedometer is stuck or broken. YES..... cable and speedometer seem to be working. While speedometer cable is disconnected, do not screw the outer sheath on just yet. Take note of the position of the notch that the ferule on the cable end would plug into. In the picture on the lower right that would be about one o'clock. Place transmission in neutral, raise a back wheel and turn in the forward direction. Check cable position. Has it turned???? YES.... everything seems to be working NO...... Plastic pinion gear inside may be broken. Remove 10mm retaining bolt and key and carefully twist and pull pinion sleeve out of transmission and inspect. Easier for you to check later than running off and buying something not needed. 1 Quote Link to comment
flatcat19 Posted August 16, 2015 Report Share Posted August 16, 2015 I misread the question. Quote Link to comment
datzenmike Posted August 17, 2015 Report Share Posted August 17, 2015 ... it's ok Moby. Quote Link to comment
datzenmike Posted August 17, 2015 Report Share Posted August 17, 2015 oh yeah, sorry that was Micro.... my bad. Quote Link to comment
GoGoGo Posted August 19, 2015 Author Report Share Posted August 19, 2015 Mike, thanks as always. Somehow I talked my 5 month pregnant wife to slide under the car and watch the sending unit while I turned a back wheel. Sure enough she said that it wasn't turning. Pulled the pinion gear out and it looked like this: I'll need to get another one. Where can I get one and how many teeth would you guess I will need to get the speedometer to be more accurate with stock rear end and 195-50-15s? You are the man and I appreciate the help a lot... Quote Link to comment
Draker Posted August 19, 2015 Report Share Posted August 19, 2015 I believe I installed a black gear and the needle is reads 65mph when doing 60 with those same tires. Quote Link to comment
datzenmike Posted August 19, 2015 Report Share Posted August 19, 2015 The teeth can be counted to be absolutely sure but they are color coded. My monitor shows that as a Green/Yellow color???. Count and let me know what that one is first. The black metal body can be re-used and just the spindle with gear replaced. Lets see what you have now first. Quote Link to comment
GoGoGo Posted August 19, 2015 Author Report Share Posted August 19, 2015 So there are 16 teeth Quote Link to comment
Sealik Posted August 20, 2015 Report Share Posted August 20, 2015 http://www.graytechsoftware.com/garage/cogcalc.asp Nissan Pt # #T Color Ratio Gears 32703-78100 16T (yellow) 3.364 37/11 32703-78101 17T (black) 3.545 39/11 32703-78102 18T (blue) 3.700 37/10 32703-78103 19T (white) 3.900 39/10 32703-78104 20T (red) 4.111 37/9 32703-86401 21T (purple) 4.375 35/8 32703-86402 22T (orange) 4.625 37/8 32703-86403 23T (green) 4.875 39/8 32707-7800 16-19t Sleeve Assy 3270766300 20-23t Sleeve Assy 1 Quote Link to comment
GoGoGo Posted August 21, 2015 Author Report Share Posted August 21, 2015 So if I do that calculator I end up with a 21T (purple gear) and would have to get a new sleeve assembly!? That doesn't seem right if Draker is using a 17T (black) and is off by 5mph at 60ish. Am I missing something? Quote Link to comment
Draker Posted August 21, 2015 Report Share Posted August 21, 2015 I wish I had a picture.. but I'm pretty sure it was black. Quote Link to comment
Draker Posted August 21, 2015 Report Share Posted August 21, 2015 I'm pulling the tranny this weekend.. I'll look at it. Quote Link to comment
datzenmike Posted August 21, 2015 Report Share Posted August 21, 2015 Tire diameter and differential ratio factor into this. Nissan vehicles don't use the same tires or gear combinations. A 23" tall tire with a 3.354 gear won't use the pinion from a 720 with 28" tall tires and a 3.354 I'll have a look tonight when I get home. The sleeve can be reused and only the pinion gear changed. There is a small roll pin to remove and it slides out. Quote Link to comment
datzenmike Posted August 22, 2015 Report Share Posted August 22, 2015 The stock 510 tire is 5.60 X 13 so 185/70R13 making the tire diameter 23.2". Your 195/50R15 tires are 22.68" That's 2.3% out. That's nothing. Reading 2.3MPH fast at 100 MPH... nothing. That's 1.15 MPH at 50 MPH. Going up one tooth will slow the speedometer 6.2% which will make it read 3.95% slow at 100 or almost 2 MPH slow at 50. The 16 tooth pinion for a dogleg 5 speed is 32703-N9016 maybe $20 in today's money? It was also used in the April '76 and up A series B-210 GX with the optional dogleg 5 speed. That's the only Nissan that the Yellow 16 tooth pinion was ever used on that will fit your pinion sleeve.. Never seen one chewed that bad. Check that the speedometer cable is free to turn . Quote Link to comment
Draker Posted August 24, 2015 Report Share Posted August 24, 2015 Here is mine: Quote Link to comment
GoGoGo Posted August 24, 2015 Author Report Share Posted August 24, 2015 Thanks to both of you. Ordered the yellow one based off of Mike's calculations and then we'll go from there. Will use GPS to determine how off the speedo is and if I really can/want to correct it. Quote Link to comment
datzenmike Posted August 24, 2015 Report Share Posted August 24, 2015 Keep in mind that GPS speed isn't that accurate. Follow a friend at 50 Quote Link to comment
GoGoGo Posted August 24, 2015 Author Report Share Posted August 24, 2015 Yeah so that order was canceled (out of stock). Called the local dealership and it's discontinued. Am I out of luck? Or will another Nissan 16T gear work. Ebay has this one - http://www.ebay.com/itm/Datsun-240Z-260Z-280Z-1971-78-Manual-transmission-4-speed-Speedo-Gear-17-OEM-NEW-/221851654429?hash=item33a763991d&vxp=mtr Transmission is out of a 1977 200SX. Quote Link to comment
datzenmike Posted August 24, 2015 Report Share Posted August 24, 2015 Only the B-210 GX 5 speed has that particular gear. It's in my post Quote Link to comment
dscottdatsun Posted August 24, 2015 Report Share Posted August 24, 2015 So what is another proper option outside your fore mentioned piece of unobtainium? Quote Link to comment
datzenmike Posted August 24, 2015 Report Share Posted August 24, 2015 I've removed one and they appear to be pressed or molded on and they are likely all the same but mounted on different spindles for the different sleeves. Any other 14 tooth plastic gear could just be 'glued' on to your old spindle. If Nissan doesn't have one then I would start an ad for any Yellow 16 tooth gear and swap it on to yours. Quote Link to comment
