btd19m Posted August 13, 2015 Report Share Posted August 13, 2015 (edited) so my project is going very well apart from a few power issues even dual battery cant fix. here are some photos of the changes. list so far razed front bars to suit load bearing and to stop it riding on the bump stops and remove steering issues (scraping on the guards at 3/4 lock) air shocks (rear) were adjusted reseated and filled to 80psi wheel alignment and all wheels set to 40 psi (back were at 45 and front at 65) new front tires for rego (1 blow out replaced both) new trailer plug (flat 7 pin kept 6 pin and got an adaptor to make sure issues can be avoided) upgraded rear lights (led) upgraded hid high beams front upgraded +100% high/low beams (h4 globes) upgraded light housings (8 total) led light bar (24 inch 120 watt bar) upgraded led park and turning lights. dual batterys. running water with water tank (60L) currently in tub waiting for mounting hardware to be fitted water pump (80psi) current piped and tapped at bullbar with control hardware on the bullbar mount. dual batterys (2 650cca 160rc hour batterys) and one extra battery for jumping if needed new stereo 2x 310 watt speakers (6x9 inch) 2x 3 inch speakers new canopy (bought off a friend) new bullbar (bought off a friend) all new wireing (not installed) new usa red carpet. (in post) new tacho (in post) new red seat covers (in post) tub liner (bought off friend) 4 tins of paint (total of about 80L) new red led dash backlighting) new overflow replaced break booster again replaced master/slave again drums have been rebuilt/machined have ordered new spark plugs and new leads from the usa. have just dropped all oil (sump/motor/diff) all fluids (brake/clutch) have re'gassed the aircon had the datsun grill plastic welded to fix a crack from getting hit with the trailer of another car tested load bearing reset timing replaced electric choke replaced both fuel filters today (doing 2 every 5000km) mesured it at 4.7L to 107km. reduced idle to 900rpm in the gate (wont idle lower - unsure why) OLD !!!!!NEW!!!!! Edited August 13, 2015 by btd19m 3 Quote Link to comment
shacks510 Posted August 13, 2015 Report Share Posted August 13, 2015 Half your oics aren't working!! 1 Quote Link to comment
btd19m Posted August 13, 2015 Author Report Share Posted August 13, 2015 Half your oics aren't working!! will sort it out now 1 Quote Link to comment
btd19m Posted August 13, 2015 Author Report Share Posted August 13, 2015 Half your oics aren't working!! should be working now. uploaded to imgur.com instead sizes are off but not overly worryed 1 Quote Link to comment
btd19m Posted August 13, 2015 Author Report Share Posted August 13, 2015 LED brake bulbs and turning bulbs + led numberplate light HID's 24 inch light bar (120 watt's) 1 Quote Link to comment
btd19m Posted August 14, 2015 Author Report Share Posted August 14, 2015 New trailer plug adjusted trailer hitch and replaced the towball after it snapped off somehow.. On a 55 degree on ramps Quote Link to comment
btd19m Posted August 14, 2015 Author Report Share Posted August 14, 2015 Almost snapped my neck and got a blood nose. Don't Park your 6x6 between the car and the staircase. Quote Link to comment
btd19m Posted August 17, 2015 Author Report Share Posted August 17, 2015 Rewired hid's and lightbar and got a quote on the back 225/75/14 tires today. Also wound up the torsion bars again and put the air shocks up to 120 psi for towing. Got new wireing part way done. Rewired dash and key. I now have an acc wire. 720 is not running at the moment. Got spark fuel everything. Just no starter motor. Quote Link to comment
Draker Posted August 17, 2015 Report Share Posted August 17, 2015 wow.. I love the truck! So cool! Quote Link to comment
btd19m Posted August 17, 2015 Author Report Share Posted August 17, 2015 lot to do still but im more then up for a challenge :) Quote Link to comment
btd19m Posted August 20, 2015 Author Report Share Posted August 20, 2015 twin batterys done VSR twin volt meters mounted using a metal blank off plate cut to size from an f150 and holes drilled for mounting (no holes were drilled to mount in the datsun the plate mounts behind an opening (ac vent and the battery meters screw onto a plate on the inner side) ran new battery leads. rewired 25% of the car today. used the same colors and stock gear just replaced wires and joined/soldered/crimped in new wires as needed. 100 amp breakers installed for both batterys. tacho is sitting ready to go. just waiting on the 2.2k resistor's new horns all new fuses tacho. dual battery system new muti meter (last one died to the fan belt) new led park lights turn lights and replaced dash lights/removed dash clock as it is blown and shorting out the dash bulbs front finished off inner set 2x 100 watt hid's outer set 2x 100+100% globes. 120 watt 24 inch cree lightbar. after market housings removed dash battery globe cut prongs and replaced (red light prevents getting rego and never turns off due to bad alt) replaced headlight wiring hard wired the hids and light bar to high beam (was on switch) led turn globes/led park lights (3w) replaced rear lights with slightly brighter led's (5w to 10w) replaced all wires from battery to cab that were lose (20ish. removed ground wire and replaced grounding point & & made a second one for the second battery added new wiring through the firewall on the passenger side (old hole aircon maybe? new wiring consists of 10x + quick connect and release 30 amp connectors and wire (sets of 2 postives) also left room for 10 more. some of the stuff used for rewireing. +125m of 30 amp load rated cable 35m of 6mm cable (red and black each 30m) dual batterys. started thinking about solar placement's and ran cable front to back for an Anderson plug at a later date 100m x10 rolls of 20amp 1.25mm wire (in and out of cab matching factory colors) ran new cable along the carby as it melted it off again (heat proofed it as well) tagged all added wires for ease of ident. ordered a 1981 datsun 720 dual cab workshop manual. (got complements on the car from the guy i was looking for the book with) ordered new gas struts (canopy ones are long dead) got a quote on locking tailgate clips. got quotes on air pressure gauge's (i have remote res air shocks in the rear) finished headlights and second battery/cab wireing about 11pm today after 2 days of it. plan to add 2 new fuse boxes (12 fuses per box) added a permanent 12v compressor under the tub as well as a portable 12v compressor and added a new lighter socket into the tub. planing to order oil/water/presure/temp gauges found alt is dead. need a more powerful replacement. (half done with the batterys/wiring) VSR rear lights front lights Quote Link to comment
btd19m Posted August 20, 2015 Author Report Share Posted August 20, 2015 some of the new gear front view (on comming lights) Quote Link to comment
btd19m Posted August 20, 2015 Author Report Share Posted August 20, 2015 second battery Quote Link to comment
btd19m Posted August 20, 2015 Author Report Share Posted August 20, 2015 removed all the wires and reran them late today Quote Link to comment
btd19m Posted August 24, 2015 Author Report Share Posted August 24, 2015 cleaned the motor/bay cut a blank off and made room for a tacho replaced the last of the globes with led's inc dash tacho at night randomly working alt worked again for about 2 hours today out of a 3 hour drive Quote Link to comment
btd19m Posted August 25, 2015 Author Report Share Posted August 25, 2015 New weber soon :) Quote Link to comment
Stoffregen Motorsports Posted August 25, 2015 Report Share Posted August 25, 2015 I have to say, get all these little bugs worked out and you'll have one bad ass little truck. And I agree with everyone else. Consolidate all your problems to one thread and make your life (and the people who are trying to help) a bit easier. Quote Link to comment
btd19m Posted August 25, 2015 Author Report Share Posted August 25, 2015 I have to say, get all these little bugs worked out and you'll have one bad ass little truck. And I agree with everyone else. Consolidate all your problems to one thread and make your life (and the people who are trying to help) a bit easier. Yeah. :) im starting to think the same. :) Quote Link to comment
btd19m Posted August 26, 2015 Author Report Share Posted August 26, 2015 ^^^needs a dual cab. Also needs a dual cab trailer ;) Quote Link to comment
btd19m Posted August 28, 2015 Author Report Share Posted August 28, 2015 new shocks on the front :) Quote Link to comment
btd19m Posted August 28, 2015 Author Report Share Posted August 28, 2015 factory 81" shocks Quote Link to comment
btd19m Posted September 16, 2015 Author Report Share Posted September 16, 2015 update. tracked the fuel problems late today. the click in the motor was a BOSCH 0580254044 installed by the po above the tank on the left hand side. since being ripped out and replaced with a stocker shes running super smooth at 650 rpm idle got the new alt in not long ago (4:34am now) 14.4v idle with 60 amps at 3k on the tach its at 123 amps. just ordered a ton of parts to get it all sorted. it goes to the workshop on the 21-23 to have the new motor rebuilt (again -_-) getting the carb rebuilt at the same time and having the clutch done(cant get to the clutch without pulling the motor currently) selling an ac bracket to a fellow ratsun member in the coming weeks. (your us prices are insane) replaced the "T connector" as it was connected to a cut wire in the cab (hence why the alt never worked well) ive just gotten some new parts to finish off the wiring. list is as follows. 2 narva 54435 fuse blocks 30 meters of 6mm red cable 30 meters of 6mm black cable 30 lugs to suit 2 100amp relay as currently everything is hooked directly the battery is draining 24/7 10 40amp relays 100 m3,m4,m5,m6,m7,m8,m9,m10 bolts washers and spring washers and nylock nuts (kit) professional carpet is being installed before its finished off at the work shop 200m of 2.5mm cable (black) 200m of 2.5mm cable (red) 3000 peace electrical connection kit 30pcs hss drill bit set new seat covers 6 stage battery charger (will be permanently installed) velcro zip ties. (got sick of using 100 packs in weeks) 1 dual usb outlet (2x 2.1amp) to replace the lighter socket drill chuck (thanks to me not thinking the fan ate the last one. 2m aux extension 2m usb extension another jigsaw.new drill.just got a 200pcs tool kit. makes things so much easier got a 4m x 2m sheet of plywood for a box to house my speakers (behind the rear seats) and replace the kick panels that have rotted away over time. got second hand door cards replaced brake pads exedy clutch kit new spark plugsused cluster (mine failed finely) total cost of AU $1131.24 812.97 US dollars the motor was only done a few weeks ago so by law its covered in full for any and all work required to fix it. registration is on the 8th of october and it will be about 500$ so for that 2 weeks i doubt much will happen. Quote Link to comment
