CGraves Posted August 10, 2015 Report Share Posted August 10, 2015 I've got a 72 240 and the transmission is a 4 speed from a 71 as best as I can tell. My previous starter had what I believed to be a bad bendix where it would only engage once every 20 tries if that so I bought a brand new one and it worked fine for the first 3 or so turns but after that it I can hear it click and spin over but it's not hitting the flywheel anymore. I'm not sure if this is a flywheel issue or starter issue. Anyone have any experience with this stuff? Quote Link to comment
datzenmike Posted August 11, 2015 Report Share Posted August 11, 2015 Is the battery fully charged? This is common with many old Datsuns... the start signal from the ignition is weak. Power from the battery has to travel about 15-20 feet through thin 45 year old wires and connections to get to the ignition and back out to the starter. Often the start signal is below 8 volts and the solenoid clicks or the starter misses the flywheel. Try this test... Find the small wire on the starter solenoid that comes from the ignition and pull it off carefully. Now make a small jumper wire from the battery positive terminal and touch it to the solenoid where the wire was. Use all caution.... Be sure car is out of gear. This wire is not protected by a fuse so do NOT touch it to any thing that is grounded. If starter works every time with a direct 12 jumpered to the solenoid it can be assumed that the start signal from the ignition is too weak. To fix this usually a cheap relay is installed to do the same thing using the weak start signal to turn it on. 1 Quote Link to comment
CGraves Posted August 11, 2015 Author Report Share Posted August 11, 2015 First of all thanks for the quick reply Mike! I was arcing across the starter with a screwdriver because the wiring and interior is in shambles at the moment but I tried the wire in hopes it might be different and as far as I can tell voltage isn't the issue so I'm starting to think its a flywheel issue. Quote Link to comment
banzai510(hainz) Posted August 11, 2015 Report Share Posted August 11, 2015 if gear looks good then the seliniod is not throw the arm out far enough. My 521 had this and I swap a starter to wok a few time then bam click click again I used a Ford starter relay I had lyugn around and made it work. Quote Link to comment
CGraves Posted August 11, 2015 Author Report Share Posted August 11, 2015 Well I either have the wrong flywheel or the teeth are in worse shape than I thought. The teeth were fairly rough but I figured it would be good enough to at least get the thing started. Does anyone know if the flywheels from a 240/60/80 are all interchangeable? 1 Quote Link to comment
Doctor510 Posted August 11, 2015 Report Share Posted August 11, 2015 Well I either have the wrong flywheel or the teeth are in worse shape than I thought. The teeth were fairly rough but I figured it would be good enough to at least get the thing started. Does anyone know if the flywheels from a 240/60/80 are all interchangeable? YUP, watch to be sure the clutch disc diameter is the same as yours. 1 Quote Link to comment
CGraves Posted August 12, 2015 Author Report Share Posted August 12, 2015 Thanks to doctor510 for the info yesterday! I was able to source a 280z flywheel so I'm gonna try and get it put in sometime this weekend. 1 Quote Link to comment
