No spark ka24de swap
  • Replies 9
I had the same issue with the ecu not powering the fuel pump but from what I am told the is not uncommon for that to happen. hook the fuel pump up to the ignition to give it power. also try turning the motor over and put a test light to power and the other side to the plug for the injectors they should pulse as it turns over
