2dat0z9 Posted July 26, 2015 Report Share Posted July 26, 2015 I got an electronic distributor out of a 77 280z. I was wondering if I can use it on the l20 I'm building if I swap the 6 point reluctor for a 4 point out of a b210 electronic distributor. Quote Link to comment
banzai510(hainz) Posted July 26, 2015 Report Share Posted July 26, 2015 why bother just find a 4 plug Quote Link to comment
datzenmike Posted July 26, 2015 Report Share Posted July 26, 2015 You will need the parts from a remote igniter EI dizzy. The 4 point reluctor and matching pick up coil only used on '78 vehicles, so '78 620, S10 (200sx and A10 (HL510). The L20B reluctor is 22115- N6100 and pick up coil 22229-N5800 The breaker plate that these parts bolt to is the same for the L28 and the L20B dizzys. 1 Quote Link to comment
2dat0z9 Posted July 26, 2015 Author Report Share Posted July 26, 2015 Tanks mike. I got the remote igniter and distributor from the 280z. I was just wondering if it would work if I put the 4 point reluctor from my b210 electronic distributor. Both distributors are almost the same. The only differences I see is the reluctor and the shaft on the b210 distributor is about 1/4 inch shorter. Quote Link to comment
datzenmike Posted July 26, 2015 Report Share Posted July 26, 2015 There are a lot of similarities between A and L series dizzys once you remove the drive gear. But the pick up coil is a different part number .... it might still work though. I listed the L20B pick up coil because it should fit. Quote Link to comment
2dat0z9 Posted July 27, 2015 Author Report Share Posted July 27, 2015 Okay. Thanks for the info. Im almost done with my engine so ill find out if it works Quote Link to comment
