Lockleaf Posted October 8, 2015 Report Share Posted October 8, 2015 With the setup you purchased, I would not run flares. You have nice new rims, just run them tucked. As rhino said, you can choose to run spacers (over about 15mm and the start to be adapters instead. They bolt on and have new lugs for the rim to bolt to. Wheel adapter doesn't just refer to changing lug pattern), but at that point you ought to see about wider or negative offset rims to fill a flare if you're set on flaring. OR if you swap to a Mazda or Toyota axle (I think you mentioned that on another thread) then you might have a wider axle and suddenly those rims will fill out those flares Quote Link to comment
dukerollo Posted October 8, 2015 Author Report Share Posted October 8, 2015 Thanks for the input. The pics are crap, but I have a little bit of poke with these. I want to run a tire that is square on the rim, currently leaning toward a 225/45. I would like to run without flares, but I don't know if I can get enough pull out of the quarter panels. I really need to get some rubber on there to see where I am at. These flares were free, so I may narrow them significantly and see how they look. Quote Link to comment
hobospyder Posted October 8, 2015 Report Share Posted October 8, 2015 Get some tires on the wheels, see how they sit and then figure it out. Don't cut anything until you know it's required Quote Link to comment
dukerollo Posted November 11, 2015 Author Report Share Posted November 11, 2015 Been plugging away at this. I am a lot of things, but fast at body work is not one of them.... I mounted up a scrapper 195/50 on the Enkeis to better asses the situation. Didn't fit, but it looked workable. I bit the bullet on an Eastwood fender roller and got busy. I was pretty impressed how much I was able to pull the arches. I now have full clearance in the rear up past the bump stops. I dig the way these look and need to get it outside to get a good picture. I should be able to do that soon because all of the bodywork is nearly finished :) . The pile of sanding dust on the floor (and probably in my lungs) is testament to that. 2 Quote Link to comment
fisch Posted November 12, 2015 Report Share Posted November 12, 2015 "Kesha puked on it." Man what a fun build thread. First I love seeing this much love go into a 80's b310. When I first joined Ratsun I don't think there was even a b310 on the site. But it is funny how perceptions change. And now the super angular look of these cars, when done right, is suddenly appealing. To the point I was thinking about saving an 82 310, but the FWD keeps me away on that one. I don't know what that tipping point is when something goes from being grandmas boring car to awesomeness. But heck even the 70's 510 was a $300 car few cared about. And at least in New England, the prices on these RWD 210s 310's has made huge leaps. Second, you are freakin funny. Third, skilled! Your thread is a trifecta of awesome and I look forward to following. 2 Quote Link to comment
dukerollo Posted November 13, 2015 Author Report Share Posted November 13, 2015 Thanks for the kind words man. Helps keep the mojo up. Small, light, and rwd is all I need. As an 80s kid, I do tend dig square cars though. Lots of e30s and Volvos attest to that. Quote Link to comment
datsunfreak Posted November 13, 2015 Report Share Posted November 13, 2015 Those new wheels look very sharp on there... :thumbup: 1 Quote Link to comment
mttam510 Posted November 13, 2015 Report Share Posted November 13, 2015 I like the wheels....with flares....looks badass! Quote Link to comment
TENDRIL Posted November 13, 2015 Report Share Posted November 13, 2015 that thing have a link suspension? Quote Link to comment
dukerollo Posted November 13, 2015 Author Report Share Posted November 13, 2015 Thanks gents. No flares needed, which I am a little torn about, but I think this will result in a cleaner look. It has a diagonal 4 link in the back. 1 Quote Link to comment
DADZSUN Posted November 13, 2015 Report Share Posted November 13, 2015 So 195/50 fit after an Eastwood pull, will the 225/45s you mentioned earlier fit as well? Just to confirm, that's a 15x8 rim eh? What's the offset and how does the front look with the same size? Great thread, I'll admit it... I giggled. Any plans for the bumpers? Quote Link to comment
dukerollo Posted November 14, 2015 Author Report Share Posted November 14, 2015 I wasn't able to scam a 225/45 cheaply enough to try it out. I was convinced that the 195 would be too much stretch on the 8" rim (et 0), but once I mounted it up, I was in love with how the tire fit and gave up the search for other sizes. I don't see anything more than a 205/50 fitting with this offset and a pull. I don't have the front suspension in place yet, or the front clip for that matter, so I can't say how it will be for sure. I am running 280zx struts, so the track will be narrower than stock, I suspect I will need a small spacer. On the bumper front, I have some Yue Loong 303 bumpers from Taiwan that I will be making metal corner caps for. They should look like the base JDM bumpers when I am finished. Quote Link to comment
dukerollo Posted April 20, 2016 Author Report Share Posted April 20, 2016 This project isn't dead, just kinda comatose...been busy with shit. Anyways.... With paint around the corner, I thought that I had better finalize tire sizes in case more massaging was necessary. I pulled the trigger on 2 more Enkei Compes and some 205/50 Direzzas. I threw them on the ol garage ornament and I still have full clearance at the bump stops. Pretty pleased with that, and the tires should be sufficiently meaty for my needs Without further ado, more potato quality photography of fittament: I should be able to get back on this pretty heavily soon. I have to finish this little motorbike so I can pull my daily A10 off the road to rape and pillage for drivetrain and coil overs etc. 2 Quote Link to comment
fisch Posted April 20, 2016 Report Share Posted April 20, 2016 Nice, glad to see you back at it, great wheels and I can't wait to see this B310 out in the sun again! Quote Link to comment
dukerollo Posted April 20, 2016 Author Report Share Posted April 20, 2016 Thanks man. Me too. Been over a year now! Fisch, you seem to have a good taste for the aesthetic, what would you say for exterior color? I am leaning toward the grey like the engine bay, or white. Most of the interior is blue. I welcome others input as well. Quote Link to comment
fisch Posted April 20, 2016 Report Share Posted April 20, 2016 I am drawn to teh lighter Datsun colors, be it blue or that light yellow or ivory or the classic bamboo tan. With your glitter booster, you could think abut a flake roof! 1 Quote Link to comment
datsunfreak Posted April 21, 2016 Report Share Posted April 21, 2016 Fisch, you seem to have a good taste for the aesthetic, what would you say for exterior color? I am leaning toward the grey like the engine bay, or white. Most of the interior is blue. I welcome others input as well. FWIW, I feel like a blue interior mandates either blue or white outside. Of course my 1200 has blue interior and is white outside, and my 510 has blue interior and is light blue outside, so I may be biased... ^_^ But you know what you never see? Light blue B310s... B) Silver would look tits with those wheels, too... Quote Link to comment
dukerollo Posted April 24, 2016 Author Report Share Posted April 24, 2016 I'm spraying this thing in the shed and don't think I have the chops to do silver. Is there such a color as dark light blue? Lol. I'm thinking a Porsche slate greyish. I mixed up some test colors and brushed them on a motorcycle tank that I need to paint. I'll post a pic when they dry. Quote Link to comment
datsunfreak Posted April 24, 2016 Report Share Posted April 24, 2016 Is there such a color as dark light blue? There's a non-metallic blue on the newer Minis that I love. Darker than "my" blue, but I've still thought about it... Quote Link to comment
dukerollo Posted April 25, 2016 Author Report Share Posted April 25, 2016 Mr. Fisch, if the car were more 70's I'd consider a bass boat roof. I thought about it hard for the A10 before the deer incursion. Mr. Freak. That is damn near what I had in mind. Having said that, I think I found a winner. It is slightly darker and bluer in real life. I'm going to sleep on it, but so far I really like it. Judge only the color, not the finish. It is just brushed on over dragonflys and rust Etc... Quote Link to comment
fisch Posted April 25, 2016 Report Share Posted April 25, 2016 Almost the color of my 1959 Datsun! 4 Quote Link to comment
dukerollo Posted April 25, 2016 Author Report Share Posted April 25, 2016 That thing is cool! Whatcha going to do with it? Quote Link to comment
fisch Posted April 25, 2016 Report Share Posted April 25, 2016 It has been sitting in my garage for years. Originally I was going to hotrod the hell out of it. But when I got it, it was so clean and original down to the hubcaps that the Datsun Gods may frown upon me if I were to do such a thing. So I will probably restore it. But I have 510's taking my attention first. Link in my sig below if you are curious. Quote Link to comment
dukerollo Posted May 15, 2016 Author Report Share Posted May 15, 2016 I made a 3 wheeler. On the ground I cut 4 inches out of the rear springs(2 coils), it still seems exremly soft. I assume the stock rate is around 100 lb/in or so, I need to do some math and figure out what they are now and see what I need to order. I'm thinking 200 lb/in. I will have 250lb springs in the front. Any suggestions? Next weekend I'm rolling it out. My garage is always cluttered, but it has gotten to the point that it is difficult to get work done. Gonna give the old shop a good douching and the pull the doner in and yoink out the desirables. 1 Quote Link to comment
datsunfreak Posted May 16, 2016 Report Share Posted May 16, 2016 I'm thinking 200 lb/in. I will have 250lb springs in the front. Any suggestions? If 250 up front, I'd say for sure at least 200 out back, if not 225. Quote Link to comment
