mttam510 Posted July 25, 2015 Author Report Share Posted July 25, 2015 Looks good bud! thank you 1 Quote Link to comment
dukerollo Posted July 26, 2015 Report Share Posted July 26, 2015 I thought this was cool before, but you have stepped things up! I really dig the fab work, keep the detIls coming please. Quote Link to comment
mttam510 Posted July 26, 2015 Author Report Share Posted July 26, 2015 I thought this was cool before, but you have stepped things up! I really dig the fab work, keep the detIls coming please.Thanks! Today was pretty boring....I 'crud thugged' the drivers side undercoating away. I have a couple of patches to make to fix some small rotten floorboard spots. So realistically I don't see the front cage pads going down for another couple weeks. NHrRA comes to town next weekend, so I will not be going to the shop to work on the nickel dime. I will post some pics from today later. Quote Link to comment
mttam510 Posted August 9, 2015 Author Report Share Posted August 9, 2015 I know this isn/t the correct place to post this but if anyone is following this thread....will be posting in classifieds as well as e-bay and SF Craigslist. Anyways here is a list of shit that needs new homes: * New Koni packing nuts for datsun strut casings: 40.00/pr * Eibach 0800.250.0550 ERS springs (slightly used, 1 test day): 50.00/pr * Carbotech XP-8 front pads, CT-166 pad-shape(280zx), brand new: 100.00, retail is 160.00 * 1 pair of Goodridge metric to straight 20 degree banjo (at caliper): 20.00/pr * Drivers side headlight bezel, straight, no rust: 20.00 * Fuse box, fair condition, has been cut, but is easily fixable with a little solder and some adhesive lined raychem.: 20.00 * LF/RF fenders, straight, no rust, side marker has been filled (welded backside with thin skim coat of filler): 300.00 ea. * fuel tank vent: 10.00 * fuel tank fill tube, was replaced just before car went into hibernation, no cracks: 15.00 * ST front ARB, 25mm, includes poly D bushes and end links: 100.00 * ST rear ARB, 19mm, includes hardware (I made a custom set up that had and adjustment plate to match the holes of the ARB, welded to the bottom of my trailing arm under the spring, so i eliminated the bar hanging in the back and the articulation issues when the endlink is supported at the bump-stop cup)...will post pics: 100.00 * 240Z aluminum drums: 60.00/pr * Bosch SR140 gear reduction starter for 280zx, effortless starts with this one (new Bosch re-man): 100.00 * rear quarter windows (tinted)..... * rear Eibach custom springs for 510, only one run of these parts were ever produced, 850lb/in, includes polyurethane upper spring pad: 125.00/pr pics of this stuff and updates to follow.. Quote Link to comment
mttam510 Posted August 24, 2015 Author Report Share Posted August 24, 2015 last week got the passengers side floorboard made and stitched in. Also got the passenger side fender well pretty much sorted as well. removed 'pie-cut' from drivers side fender well, made a new patch and stitched that in. Found some more rust on drivers floorboard so i removed that too. Cut the old bashed in floorboard (bashed to clear the collector) and boxed that in, and crud thugged the bottom of the other side of the car....so its almost stripped of undercoating. some small patches to be made in the rear wells and stitch welding the frame rails up next. this past sat, i pulled the hubs and bearings from the rear LCA's. Blasted them prepping for re-enforcement of the bearing carrier and 2.5" weight jack arrangement. PIctures to come today..... Quote Link to comment
Mattndew76 Posted August 24, 2015 Report Share Posted August 24, 2015 Did you take any pictures of your floor process? Quote Link to comment
mttam510 Posted August 26, 2015 Author Report Share Posted August 26, 2015 yes....I have pics of it all, but not a step by step....hopefully post tonite. Quote Link to comment
mttam510 Posted October 17, 2015 Author Report Share Posted October 17, 2015 ok....been a while, been pretty busy with life but finding a few hours a week for the 510....lot's of pics to post here goes... Rust be gone.....yikes! You can see the beginings of the rearward push of the front fender wells.. new steel welded back in place, will be seam sealing and POR 15 the floorpan once all welding and grinding is complete..I still need to grind the welds at this point. Quote Link to comment
mttam510 Posted October 17, 2015 Author Report Share Posted October 17, 2015 pass front fender well taking shape... cut out old pounded floor (comp header), and replaced as I really wanted it... view from underneath....rust there too, not horrible, but pitted beyond where I wanted this car to be....so pretty much the slightest bit of rust.....it was coming out with a death wheel.... Quote Link to comment
mttam510 Posted October 17, 2015 Author Report Share Posted October 17, 2015 drivers fender well....almost there... rusted trunk floor gone.....18 G Fuelsafe aluminum can cell going in place....but not before more work to the chassis...more stitch welding.... 1 Quote Link to comment
mttam510 Posted October 17, 2015 Author Report Share Posted October 17, 2015 resistance welds gone, T/C cups removed. Prep for boxing the support and welding clevis mount in place raised 20mm. The to-do list is endless...... Quote Link to comment
mttam510 Posted October 17, 2015 Author Report Share Posted October 17, 2015 just about finished with the front crossmember project....here's where i was at on Saturday, I have since rosette welded the bottom plate to the boxed x-member. inside drivers side...in progress...but close. more drivers.....enough for tonight. time for Plineys with the wife! :thumbup: 7 Quote Link to comment
mttam510 Posted October 29, 2015 Author Report Share Posted October 29, 2015 Almost finished with the front x-member project, welded the seam over the weekend and gave it a quick blast in the cabinet before going to the platers... sometimes you just got to get in there and really take a good look at it! 1 Quote Link to comment
Draker Posted October 29, 2015 Report Share Posted October 29, 2015 sometimes you just got to get in there and really take a good look at it! 4 Quote Link to comment
mttam510 Posted October 29, 2015 Author Report Share Posted October 29, 2015 Exactly! LOL Quote Link to comment
mttam510 Posted November 1, 2015 Author Report Share Posted November 1, 2015 Good progress this weekend. Have both 'A' pillar bars bent....still needs some final tweeking but really close. I sectioned a portion of the roof/frame (where the visor mounts), to allow room to push the cage up out of the way as far as possible. Looks like it will be pretty rad, the OD of the tubes are almost on the skin. Also cut the spring buckets out of the lower control arms, in prep for rear weight jacks. I want to get the plates welded in so i can send to plate. I have pics of all of this, but took all of the with a 'normal' camera, will try to get them posted tonight. Quote Link to comment
Busta Nut Posted November 10, 2015 Report Share Posted November 10, 2015 My bad...... :lol: Good to see this here!! Great work!! 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 and finally the pictures as we currently sit....pretty stoked stock dash frame will fit nicely with a little trim... 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 dashbar is kinked slightly to follow the firewall. I will be adding tubes that pick up from the dashbar through the fire wall and landing on the strut towers. will post as soon as it is complete. same vantage point but you can see the 1" tube gussets at the upper corners of the headache and 'a' pillar bars. i am thinking of finishing the corners with sheet and flared holes....DTM style 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 that bars OD is touching the skin at the kink....you can't shoehorn a cage in any better that that.....it really turned out sweet. w00t 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 next up door bars 1 Quote Link to comment
Busta Nut Posted November 12, 2015 Report Share Posted November 12, 2015 Lookin' great!! 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 definitely going with flared hole sheet along the windshield portion of the 'a'pillars stitched to the chassis.....again opting for a little more DTM style and straying from the vintage style cage.....however, i am keeping it real with the L-series.....too bad OS giken doesnt make a 4 cyl head..... 1 Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 Lookin' great!! thank you. Quote Link to comment
mttam510 Posted November 12, 2015 Author Report Share Posted November 12, 2015 Hopefully i will get a box of goodies from the platers tomorrow.....we had a batch going out at work so i did the mustache bar and steel spacer for the diff, stub axles and inner hubs, front x-member studs......x-member goes with another batch in a week. Hopefully I will have the rear arms ready to go as well.....i will post pics as I receive parts. Beer time..... Quote Link to comment
