JohnVander Posted July 20, 2015 Report Share Posted July 20, 2015 Problem with my 71 1200, can someone give me some ideas were to start? What should I be thinking, were should I be looking? Thanks! Quote Link to comment
datzenmike Posted July 20, 2015 Report Share Posted July 20, 2015 Bulbs both burned out? Do the dash and the front marker lights work? NO.... then the fuse is possibly blown or the headlight switch isn't working YES... then there is a break in the connection or a loose plug between the interior and the back of the car. Open the trunk and find the harness. Check all visible plugs. Quote Link to comment
JohnVander Posted July 20, 2015 Author Report Share Posted July 20, 2015 Dash lights do not work, so I'll check that switch. Thank you. Quote Link to comment
datzenmike Posted July 20, 2015 Report Share Posted July 20, 2015 Fuses are more common to blow. Turn lights on and briefly place a quarter across the fuse terminals. If you find one where the lights come on, replace it and see if it it continues to work or blows again. If it immediately blows then there is a wire touching ground somewhere and this needs fixing. Could even be a bulb screwed in wrong. If the lights stay on, well it was just a fuse. A fuse may also just not be making good contact with the prongs that hold it. Quote Link to comment
banzai510(hainz) Posted July 20, 2015 Report Share Posted July 20, 2015 my 521 when the tail lights dont work my dash light dont work. Find out it was a blown fuse. Ck the fuse or replace even if it looks good. maybe be broken at the ends unless you ohm checkk it 1 Quote Link to comment
