So this happened today
B210GX
$200  + 3 ish hours drive = 2) A14's and a 60 Series 5spd
http://community.ratsun.net/classifieds/item/6209-fs-1980-b210/
Says it didnt run... In my opinion they ALL run.   but some of the things  are like, why did you do this.
After about 5 mins I found out it was 180* out of time.
Tomorrow I will run some fuel line and hook up the coil and throw a battery in there and listen to her purr.   X fingers  :)
Then yard the motor/trans out ..
classifieds-10325-0-00747200-1436760799_
classifieds-10325-0-67476500-1436760809_
classifieds-10325-0-79826800-1436760837_
classifieds-10325-0-97058500-1436760857_
P.s. these are his pics not mine  JS
  • Replies 21
I am keeping the engines   one is in pieces  literally  in a box in the drivers seat .
Remember I have two 1200's that need engines as well.
The car will get parted  I think.
Flatcat what happened to your coupe?  and yes Omak
Nanner I have radiators galore. but thanks.  I am not sure about Blue lake as of yet..
-Mike
Fuel filter clogged so just go around it. Looks like an attempt at maybe a cone filter? Accell coil??? really?
He kept the accell coil..    he can have it  LOL
to damned hot to go out and work on it today,
Large oval intake ports with a round port intake ground to "kinda match" ..  all the in/ex  nuts were just  a little over finger tight.
Every orifice that has not been blocked off has leafcutter bees nests in them.
The Radiator is one of these
 http://www.ebay.com/itm/Aluminum-Radiator-FIT-Austin-Rover-Mini-Cooper-850-1000-1100-1275-MT-1959-91-/161743364634?fits=Model%3AMini+Cooper
Anyway   motor is out .. while on the lift it was draining into the drain pan then I noticed oil dripping...
almost as if there is no rear main seal....rrrrrrrrrrrrr   WTF!
