Dfinfrock64 Posted July 15, 2015 Report Share Posted July 15, 2015 I'm attempting to pull the engine in my 78 Datsun 620. Do I need to remove the steering component under the oil pan before I can pull the engine? Quote Link to comment
datzenmike Posted July 15, 2015 Report Share Posted July 15, 2015 No. The engine lifts up and out. Remove the battery FIRST THING. Next the distributor cap and wires to protect them from being broken. Take the hood off and radiator out.... if possible disconnect the hoses from the engine rather than from the rad. Remove plastic fan from water pump, (again to prevent breaking) removing the water pump is even better and gives more room. Disconnect the exhaust down pipe and the two heater hoses from the block and head. Unplug the engine harness plug just behind the alternator. Fuel line from the filter side of the mechanical pump. 1 Quote Link to comment
]2eDeYe Posted July 15, 2015 Report Share Posted July 15, 2015 Are you pulling the transmission as well? Quote Link to comment
Farmer Joe Posted July 15, 2015 Report Share Posted July 15, 2015 every time ive pulled the engine from my 620 ive undone the 2 bolts on the idler arm on the passenger side of the frame. each time was with the tranny still in the truck. makes it so much easier to get the oil pan past, since the engine has to move forward a few inches to get clear of the input shaft of the trans. drop that sucker down and get your engine out!! lol 4 Quote Link to comment
KoHeartsGPA Posted July 15, 2015 Report Share Posted July 15, 2015 Kool, another local guy!, we have few guys near you in Springfield. Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 Welcome to Ratsun! Lets see some pictures of this truck! Lots of local guys that know a thing or two.. Quote Link to comment
datzenmike Posted July 16, 2015 Report Share Posted July 16, 2015 every time ive pulled the engine from my 620 ive undone the 2 bolts on the idler arm on the passenger side of the frame. each time was with the tranny still in the truck. makes it so much easier to get the oil pan past, since the engine has to move forward a few inches to get clear of the input shaft of the trans. drop that sucker down and get your engine out!! lol Makes total sense. Good one. 1 Quote Link to comment
