bdoggs87 Posted July 15, 2015 Report Share Posted July 15, 2015 So I've been reading tons and tons of forums and there is never a straight answer so I'll ask here. Every forum that i read gets side tracked to where the original question gets lost and forgotten (literally) due to people complaining on why get a r200 differential when you can get a r180/160 then people get more complicated on the technical terms of the difference in the differentials. So this past weekend, I was lucky enough to make a trip to Canada (best place for Datsun parts) and picked myself up a r200 CLSD Differential and the CV Shafts from an 88 300zxt. The reason for the r200 was basically I couldn't pass it up knowing some people say it's way more than needed plus i had another person willing to sell me a open diff r200 i could have converted to LSD. What I've been trying to research is what do I need to do to properly install this bad boy. Things I know and read: Wolf's Creek has a CV Conversion Kit Passenger side will be an issue due to length Can use 280zx U Joints (?) but can only handle so much Will need a different/modded mustache bar (probably order one from Datsport) To use the 300zxt CV Shafts, the passenger side needs to be shortened but unfortunately i don't have a machine shop to re-spline the shaft So the question is, is there more needed to make this install work? Also what driveshafst are people using for an r200 to SR20? Quote Link to comment
datzenmike Posted July 15, 2015 Report Share Posted July 15, 2015 What engine are you running that you think you need an R-200? They are boat anchors and 3.7 ratio same as your 510 so no improvement there. Did you confirm that it is a clutch LSD? Viscous LSDs were used from January '88 and on. 1 Quote Link to comment
Doctor510 Posted July 15, 2015 Report Share Posted July 15, 2015 So I've been reading tons and tons of forums and there is never a straight answer so I'll ask here. Every forum that i read gets side tracked to where the original question gets lost and forgotten (literally) due to people complaining on why get a r200 differential when you can get a r180/160 then people get more complicated on the technical terms of the difference in the differentials. So this past weekend, I was lucky enough to make a trip to Canada (best place for Datsun parts) and picked myself up a r200 CLSD Differential and the CV Shafts from an 88 300zxt. The reason for the r200 was basically I couldn't pass it up knowing some people say it's way more than needed plus i had another person willing to sell me a open diff r200 i could have converted to LSD. What I've been trying to research is what do I need to do to properly install this bad boy. Things I know and read: Wolf's Creek has a CV Conversion Kit GOOD BUT EXPENSIVE! Passenger side will be an issue due to length YUP Can use 280zx U Joints (?) but can only handle so much SURE Will need a different/modded mustache bar (probably order one from Datsport) MODDED DIY To use the 300zxt CV Shafts, the passenger side needs to be shortened but unfortunately i don't have a machine shop to re-spline the shaft YUP EXPENSIVE IF YOU CAN FIND A SHOP THAT WILL EVEN DO IT FOR YOU So the question is, is there more needed to make this install work? YES, stick with the R180 Also what driveshafst are people using for an r200 to SR20? WHY ARE YOU GUYS ALWAYS TRYING TO REINVENT THE WHEEL? Quote Link to comment
toylet Posted July 15, 2015 Report Share Posted July 15, 2015 510s come with 3.9 unless it is a 68. The driveshaft shop can make you a driveshaft for anything. 1 Quote Link to comment
bdoggs87 Posted July 15, 2015 Author Report Share Posted July 15, 2015 datzenmike - I plan on using it for a SR20. As to the if the r200 I picked up is a VLSD, I believe, correct me if I'm wrong, that the CLSD were used in all the late model 300zx turbos (87-88). The only VLSD were in the 88SS version of the 300zx (Shiro Special). Easiest way for me to confirm is to count the splines since the VLSD r200 Diff from the Shiro is a different count. Also I'm quite positive the guy who sold it to me didn't own a Shiro due to the fact he's owned it for 7 years and it was red while the Shiros came in pearl white. Also heard stories how those with SR20 tend to break their R180s so since i was able to find an original r200 LSD might as well use it. Doctor510 - yes guys are trying too reinvent the wheel that's why it's hard for guys like me find it a hard time to just find the correct forums where the simple information are with having to fabricate or spend the extra money for fabricated stuff. I've read that some users are using drive shafts from Drive Shaft Shop but they don't necessarily make them for 510's so it's hard to even figure out which to get (also it's freaking expensive). I see what you did there with the R180 suggestion :thumbup: Toylet - not sure if you meant drive shaft shop as in the website or a drive shaft shop shop like auto shop haha 1 Quote Link to comment
datzenmike Posted July 15, 2015 Report Share Posted July 15, 2015 The SS had VLSD but my info doesn't say if it is in just those or all Jan '88 and up turbo cars. Take the back cover off and look. 1 Quote Link to comment
scooter Posted July 19, 2015 Report Share Posted July 19, 2015 If its a stockish sr stick with the 180, if your creating massive retardedness with 500 hp in a 510 then okay 2 Quote Link to comment
Modern-Motorsports Posted September 3, 2015 Report Share Posted September 3, 2015 Hi I have a complete bolt in CV conversion kit for the 510s and 240Zs. More info can be found on my web site. Thanks Joe Quote Link to comment
DISLEXICDIME Posted September 3, 2015 Report Share Posted September 3, 2015 http://www.datsun-france.com/Ratdat/ratdatblog/?p=292 Quote Link to comment
