gen4maxima536 Posted May 31, 2007 Report Share Posted May 31, 2007 What roadster clutch (year and brand) would be good for a 510? will a roadster clutch work with any transmission 4 spd, 5spd, dogleg that i can put in the 510? are there any other roadster specific parts that need to be obtained i.e. throw out bearing, flywheel? Quote Link to comment
slodat Posted May 31, 2007 Report Share Posted May 31, 2007 It is for a '70 2L Roadster. You need a 200mm flywheel, which is what the stock L16/L18 flywheel is in a car. If you have an L20b, the 200mm flywheel is a little harder to find. All you order from the Roadster is the pressure plate, the rest is all stock 510 stuff. Will work with any L series transmission - 4speed, dogleg 5 speed, Z, ZX, etc. Quote Link to comment
gen4maxima536 Posted June 1, 2007 Author Report Share Posted June 1, 2007 whats the normal flywheel size for an L20b? so i could just take the flywheel from a 16 and put it on the 20 and sounds like i'd be set Quote Link to comment
84TAVeRT Posted June 1, 2007 Report Share Posted June 1, 2007 for an L20b... i recommend the 280z turbo clutch and pressure plate :) Quote Link to comment
slodat Posted June 1, 2007 Report Share Posted June 1, 2007 The 280ZX turbo clutch and pressure plate are 240mm. 620 trucks have 225mm flywheels. Cars - 510, 610, 710, etc have 200mm flywheels. L16 & L18 are 5 bolt flywheel. L20b, L24, L26, L28 are 6 bolt flywheels. I run a 225mm flywheel with a 240Z clutch and pressure plate. Quote Link to comment
slodat Posted June 1, 2007 Report Share Posted June 1, 2007 for an L20b... i recommend the 280z turbo clutch and pressure plate :) There is no 280z turbo. The turbo came in the 280ZX. I know it seems like nit picking, but it's a significant difference. Quote Link to comment
banzai510(hainz) Posted June 1, 2007 Report Share Posted June 1, 2007 Does this car need a 280zx turbo clutch????750KG hate to find out its a stock Lseries. The Roadster pressure plate is fine and its somewhat cheap 30210-20111 order thru nissanparts.cc or nismoparts.com enter part # However the 200mm 6 bolt flywheel is harder to find to fit the L20. Unless you have one already. otherwise most are the truck type 225 mm or the Z flywheels.L20 that came in cars 610,710 and the 77-79 200sx anf the laterA/10/510 series with the l20 and ealey Z20 motor. L20 trucks 620 720 have 225mm But remember if you use a 225mm flywheel you need the T/O bearing and sleeve from the yr it cam from. ,example a 620 truck set up truck flywheels are HEAVY!!!!!!!! You can order a Fidanza 77-79(200sx) 200mm 6 bolt 10 pounder if you have about 340$ http://www.prostreetonline.com/pnsku/143121.asp Quote Link to comment
datzenmike Posted June 1, 2007 Report Share Posted June 1, 2007 The '80-'81 200sx Z20 and the '82-'83 200sx Z22 had the 200mm flywheel as well Quote Link to comment
slodat Posted June 1, 2007 Report Share Posted June 1, 2007 I had Dan Hall lighten my 225mm flywheel. I think it is about 16lbs. Quote Link to comment
banzai510(hainz) Posted June 2, 2007 Report Share Posted June 2, 2007 slodat Could you tell the difference with a lighten wheel? I had ordered a lighten stock one from a guy on Oregon. Maybe it was Dan He did it as a Hobby. Put new ring gearon also 150$ Quote Link to comment
slodat Posted June 2, 2007 Report Share Posted June 2, 2007 I haven't driven it yet. Getting very close... Quote Link to comment
datsunaholic Posted June 2, 2007 Report Share Posted June 2, 2007 The '80-'81 200sx Z20 and the '82-'83 200sx Z22 had the 200mm flywheel as well Not in the US- they had the 225mm in all S110 200SXs here. Quote Link to comment
Fineline Posted June 3, 2007 Report Share Posted June 3, 2007 Could you tell the difference with a lighten wheel? I scored a lightened 240mm turbo flywheel for $10. It weighs 13.5 lbs and you can definately tell. I only had an L-16 stocker to compare it to though. Quote Link to comment
