Trophy24 Posted August 7, 2016 Report Share Posted August 7, 2016 What is the product you switched to for primer? 1 Quote Link to comment
the510keeper Posted August 11, 2016 Author Report Share Posted August 11, 2016 This stuff works amazing all the way around, and also comes in a high build Hood time Hood has a minor seperationa at the latch as a lot of them do, so here is what i do Take a air grinder put a new disc on both sides Push the panel bond between the skin and frame, and clamp together with vise grips, using a piece of wood on each side 4 Quote Link to comment
the510keeper Posted August 12, 2016 Author Report Share Posted August 12, 2016 Im staying mostly focused, other then adding to the stock of Datsuns hinges were rebuilt before door alignment, now need to be painted, All exposed hinge bolts tread were wire wheeled, Then screwed in to the hings and garnet blastednthe heads for paint. Hood part 2 Seam sealed DP40LF Yes it is grey green and the top color is white, but I think the DP40 holds better over bare metal then the white DP. however if the areas are already primed with something i would run white DP. my 2 cents I let dry over night and resand with 600gt wet in a soapy bucket of water. Morning is a better time to paint then evening. Ive been installing little bolts so treads don't get filled up with paint 5 Quote Link to comment
the510keeper Posted August 18, 2016 Author Report Share Posted August 18, 2016 Doors are next to paint Sanding, these have been sandblasted for some time but i like to sand them smooth with 150gt. and find any problems. Super sonic line is super cool, feeling good here One down 3 to go. Painting soon very soon 2 Quote Link to comment
the510keeper Posted August 19, 2016 Author Report Share Posted August 19, 2016 Found this dead guy, wrapped in a shirt between doors Door number 2 Door number 3 Very happy so far Then i found this on driver doors and last one to sand, over looked it in the past, 2 hair line cracks Welded the cracks then used a grinding wheel, wasn't going for perfect smooth, didn't want to take to much of the extra metal off. tools needed for final blocking Quote Link to comment
AtomChurch Posted August 20, 2016 Report Share Posted August 20, 2016 This car has come so far! It is even older then my car! Gotta like vin numbers that start with zeros! 1 Quote Link to comment
the510keeper Posted August 25, 2016 Author Report Share Posted August 25, 2016 Da hood step 2 Trunk lid is for another project Doors 1 Quote Link to comment
Draker Posted August 25, 2016 Report Share Posted August 25, 2016 Been trying to do a trunk lid... for weeks now. ugh. 1 Quote Link to comment
Draker Posted August 25, 2016 Report Share Posted August 25, 2016 Those panels look great!! I wish mine was to that point.. 2 Quote Link to comment
the510keeper Posted August 25, 2016 Author Report Share Posted August 25, 2016 Real happy with how well everything is coming out, super sonic line in order and sheet metal is flat, Paint sprayed out great. These panel all got blocked and primed min 4 times. Each time i actually black a ton of material off so just to use the material needed to make flat. and not to get to thick of a material thickness. Got up early and wet sanded everything with 600gt then wax and grease removed and painted 2 Quote Link to comment
fisch Posted August 25, 2016 Report Share Posted August 25, 2016 Purty. Id say so clean I'd eat off it, but they are too clean to eat off of. 1 Quote Link to comment
Dolomite Posted August 31, 2016 Report Share Posted August 31, 2016 James asked me to update the thread for him, his phone crashed due to a virus from a gay porn website. He spent many hours sanding and buffing the trunk lid, looks great. 4 Quote Link to comment
the510keeper Posted September 1, 2016 Author Report Share Posted September 1, 2016 It's OK cause its my dog 2 Quote Link to comment
Charlie69 Posted September 1, 2016 Report Share Posted September 1, 2016 Looks great! Blaming the Dog! LOL Quote Link to comment
the510keeper Posted September 11, 2016 Author Report Share Posted September 11, 2016 Buffing time, 1st sand by DA sander 1500gt 2nd wet sand 2000gt 3rd wet sand 2500gt 4th Buff with wool pad and cutting compound 5th Polish with foam pad and fine polishing compound 4 of 5 panels made it. Been awhile since i buffed and burnt through the white on the first door FUCK See the hair line of grey 1 Quote Link to comment
the510keeper Posted September 11, 2016 Author Report Share Posted September 11, 2016 Now back to frame rail issue, really wish I did this in the beginning but no idea shit changed from 68 to 70s This is what it needs to look like Still need to do the welding, trying not mess up the engine bay paint 3 Quote Link to comment
S30Jay Posted September 13, 2016 Report Share Posted September 13, 2016 No matter how you try, it STILL doesn't look like as much work as it is. It just doesn't. Great job by the way! I never wetsanded with a DA, my old boss was against them.... Said too much vibration and thought it could cause a wavy finish. Idk, like I said I never tried it. Always wetsanded with a block. And I feel your pain on that door too, I've ruined a few paint jobs with those wool pads, foam is more user friendly to me. What compound do you use these days? I always used 3m perfect-it. Seldom do I do anything perfect.... 1 Quote Link to comment
Ranman72 Posted September 13, 2016 Report Share Posted September 13, 2016 damn i hate it when this happens its all looking great though keep up the keepen on 1 Quote Link to comment
Draker Posted September 13, 2016 Report Share Posted September 13, 2016 Minor setback.. you'll get it patched up no problem. Sucks though. 1 Quote Link to comment
the510keeper Posted September 13, 2016 Author Report Share Posted September 13, 2016 Yep the act of the fix wasn't the worriment, it was burning the paint that is finished on the inside of the engine bay. Thanks for the positive feed back. And it was a success This was Metalguy Chris idea i went with on the fix here is the photo text Lots of wet rags keeping things cool Seam sealer and DTM and done 4 Quote Link to comment
kerleybird Posted September 14, 2016 Report Share Posted September 14, 2016 Solid! 1 Quote Link to comment
Ranman72 Posted September 14, 2016 Report Share Posted September 14, 2016 that 68 is no longer original :devil: :devil: :devil: :devil: :devil: looks great 1 Quote Link to comment
the510keeper Posted October 12, 2016 Author Report Share Posted October 12, 2016 Final sanding begins 3 Quote Link to comment
the510keeper Posted October 24, 2016 Author Report Share Posted October 24, 2016 Sanding and more sanding Rocker done wanted to spray fenders at the same time but, they need more work See the big low spot 1 Quote Link to comment
the510keeper Posted October 24, 2016 Author Report Share Posted October 24, 2016 paint time Wanted to see it in the sun, check the super dildo sonic fucking pain in the ars line. Sanded again, that's why you see grey peaking through white sealer Resanded the door i blew threw with the buffer Painted yippi 3 Quote Link to comment
