Eriks Posted June 28, 2015 Report Share Posted June 28, 2015 Does the L series have the same oil pan on 610 and 620 ? Will a L20B with 620 oil pan fit in a 610 ? Thanks Quote Link to comment
MicroMachinery Posted June 28, 2015 Report Share Posted June 28, 2015 620 and 610 pans are not the same. I do believe there are clearance issues using the 620 pan in a 610. Just swap a 610 pan and oil pickup onto the 620 engine. Quote Link to comment
datzenmike Posted June 28, 2015 Report Share Posted June 28, 2015 The 620 has a cross member and a steering cross rod in front of the wheels that passes under the pan at the front. The deepest part is therefor from the middle and towards the back. Cars are steered from behind the wheels and the steering is behind the center of the oil pan. Car pans tend to have the deepest part more to the front. 1 Quote Link to comment
