Thermostat housing question
510farmer
After finding a crack on my lower housing by my sender unit
I looked around, and I was able to find a brand new one by searching the Nissan part #
We'll after getting it everything is exactly the same as the old. EXCEPT! The the side of the housing where the little hose barb fitting comes out. My old one had a pipe size of 25/64 unknown thread pitch
The new one looks to be 63/128 unknown thread pitch
I tried a 1/4 SPT and it goes in about 11/2 threads than stops I did find a metric. Bolt with a 20 thread pitch that would screw in but felt a smidge loose
Is this a BPT?
I would post pics but I have windows 12,000 and it hates photo bucket
Any help
Thx farmer
  • Replies 26
Buy yourself a 1/4 or 3/8 or whatever NPT tap and update it to modern, widely available, NPT threads. Any Kragen or Pep Boys or O' Douche Bag's store will have a NPT nipple on the shelf.
Don't beat your head against the wall trying to keep it original. Drive it!
Ya that's always a option,,,,,,
But with all this Datsun knowledge on here
No one knows what the size or thread pitch
This could be?
Thx farmer
I think Mike is right and that it is metric taper pipe thread. Here is a good tech sheet http://mdmetric.com/tech/thddata22-1.pdf
What are you going to do with this info? I really doubt you'll be able to buy MTP fittings easily here in the states. If you do find them, let us know where.
I get spare housing just for when the sender brecks
Lol Hainz
It not the sender hole it's the hose barb hole
I'm going to bring it to my machinist friend so we can find out the exact thread and size
Do it right or not at all!
Farmer
You stated the pipe size was 25/64 ". Do you have a thread gauge to measure the tpi (threads per inch)? It sounds like 1/8 th npt to me. The od of the nipple is .405 " which is a tad larger than 25/64th. 1/8 npt - 27tpi.
I believe this is the same part I replaced several years ago and I wound up getting a ss 1\4 npt nipple and put Teflon tape on the threads and screwed it in as far as I could and torqued it down good and it sealed fine. I will take a pic tomorrow.
This is what I did on my 78-620.  I threaded a 1/4 NPT nipple into the lower housing, then used a 1/4" ss Tee to hook up my two hoses.  The heater hose fits good on the 1/4" nipple but I had to use a stainless steel tubing fiting for the top (smaller) hose.  I had all these fittings available to me (fringe benefits) at the time so I was not out any cost.  I don't really know how much they would be to purchase them.
All right I have found out what it is
Savag- it on the lower thermostat housing on a L16 different part than your pictured
But thx
Ok so is everyone ready
Lady's and gentlemen
It is
1/4 BSPT.........
1/4 20 pitch does fit but it is loose
1/4 inverted flare thread works but is loose
So after my machinist friend and I determined the thread
The Bspt is 19 threads per inch
That's why the standard npt starts to go in but stops
We found a fitting I could work with at a hydraulic shop
Another Dato! Mystery solved
Thx for the help
Farmer
I had to buy a 1/4 BSPT tap last year for a TJM air locker install. Never thought I'd need one of those...
So you need the fitting (nipple) or the tap?
No I'm good I found parts at a hydraulic shop , that should work
What gets me is
Are there more threads on the engine other than the few we know about that are actually BSPT
That folks are cramming NPT into
Because like stated earlier NPT would start about 1 1/2 turns
Farmer
Well I'm sure there are a lot of guys trying to fit them, but the only right way to fit a NPT fitting in the BSPT hole is to run the NPT tap into it.
Really, it's not a problem. If it were a head bolt or some fastener that is removed regularly exercising the threads often, it may not be acceptable to do this method of retapping, but we're talking about something that gets installed, with sealer, and then never removed again, unless it gets old, rusted and broken.
My comment earlier about beating your head against the wall...what I meant was, why take all the time to have your machinist friend help you figure out the thread pitch and then take even more time to try and find the exact right part with corresponding thread pitch? A NPT nipple can be got at any auto parts store, online car parts store, Ace hardware, etc. You can get them that look pretty darn close to OEM Nissan and if they ever fail, off to the hardware store to buy another. No time wasted at all and not even remotely resembling a hack job.
I understand and that was a option
I just wanted to know what it was, more of a personal goal I guess you would say
And now when some one comes up with the same question, there is a answer
Just like your answer in my oil thrower question thread
Got to keep feeding the dato data base
Thx
Farmer
  • Like 3
I din't tap mine out but I could have.  I have some pipe taps in the shop and several size tap handles.  I worked maintenance in plants for years and was a machinist and tool and die maker for 16 years before retiring in 2013.  I knew enough about fitting tapered pipe fittings that if it screwed in by hand 1 1/2 turns that I could make it seal with teflon tape and tightening the crap out of it.  If you look at my pics you can tell the nipple that is in the housing did not screw in as far as the end that is screwed into the tee but it sealed and hasn't leaked a drop in about 10 years so for me it was a Happy Ratsun ending that cost me nothing but an hour or two of my time!  I understand if someone wishes to use the OEM parts and searches to find the exact size that it calls for.  I certainly respect that and it may help someone in the future who runs in to this same issue.  For me, it's all about what works and what is the least hassle for me to get the job done and get my truck going again.  I knew that I had the option, if it did not seal, to back it out and run a 1/4 NPT tap in there about 5-7 rounds and then I know it would seal.  I got lucky and it was close enough to the right size and TPI that it worked without tapping it out!
