mjp1531 Posted June 18, 2015 Report Share Posted June 18, 2015 Hey guys. I recently purchased a 72 Datsun 1600 521. There are definitely some wiring issues that I'll need help with. The kid who had the truck said the headlights didn't work, nor did some of the other lights, so he tried his hand at fixing it. I haven't narrowed down what lights work or not yet, because one look under the bed showed that I need to tidy up his crappy work. Firstly, the wiring coming from the taillights is spliced and hacked... Mostly exposed twisted wire ends. Does anyone have any pictures of their wiring from each side in the rear? I found a diagram but honestly it's confusing as hell, and I'd like to see the colors lol. I'm not an expert at wiring but I'd like to think I'm not too dumb to learn. Also, the spark plug wires weren't connected. Can someone point me in the right direction of getting then plugged into the distributor cap in the right order? I know I'll have many more questions, but I figured I'd start there first. This truck needs some work but it looks to be like something my teenage son and I can learn on. I look forward to the work :) 1 Quote Link to comment
Oregon_PLG222 Posted June 18, 2015 Report Share Posted June 18, 2015 You should try to find a manual as soon as you can. You'll need it. There are many different ones. Some are for 510/521 and some are for trucks. Firing order is 1342 I'll try to get a pic under mine when I get home tonight and post it. I drove my 510 to work today or I'd do it now. I saw a color wiring diagram and I'm pretty sure it was on ratsun. Try searching; you might find it. Good luck. 1 Quote Link to comment
Oregon_PLG222 Posted June 18, 2015 Report Share Posted June 18, 2015 Oh, and post the obligatory pics. 1 Quote Link to comment
LenRobertson Posted June 18, 2015 Report Share Posted June 18, 2015 I'm pretty ignorant on 521s, but here are some links that may help: http://www.davidcmurphy.com/olddat/620tech2.htmThis site is aimed at 620s, but I suspect some of the info applies to 521s. http://datsun510.com./manuals/index.htmlHas 521 Factory Service Manual. http://manualmotor.blogspot.com/2012/08/datsun-manual-download.htmlA huge collection of Datsun manuals. I skimmed through it really fast. I think I saw a Haynes manual for 521s. Also "How to Keep Your Datsun Alive" is there and has lots of basic info. I find it hard to read large manuals online. I much prefer to have an actual book in hand. But seeing the online version can tell you whether or not it is worth going to eBay and buying a print copy. Sometimes sorting out wiring is a matter of trial and error. Get a 12V test light or multimeter, then turn on the tail lights or one side turn signal or whatever. Then go back to your cut wiring harness and see which wire has power. But a readable wiring diagram helps too. The 521 Factory Service Manual may have one. Len 1 Quote Link to comment
DanielC Posted June 18, 2015 Report Share Posted June 18, 2015 Wiring diagram. Lights only diagram. 2 Quote Link to comment
mjp1531 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Wow thanks for the replies! Now that I'm totally intimidated by that wiring diagram, I guess I'll get under the truck and stare at it for a while lol 1 Quote Link to comment
DanielC Posted June 18, 2015 Report Share Posted June 18, 2015 The total wiring diagram is intimidating. What you do is break it down into parts. Then it is simple. One thing about a 521 is independent turn, and brake lights. Most vehicles use the sale lamp in the light fixture for both functions, Not so with a 521. See this thread about 521 tail lights. http://community.ratsun.net/topic/18092-521-taillight-rebuilding/?hl=taillights 521 tail lights have four wires on each tail light assembly plug. They SHOULD ground to the bed of the truck. It is common for the tail light assembly to lose ground. A quick fix it to add a ground wire from the tail light metal frame, to the frame of the truck. The four wires are reverse light, stop light, turn signal, and tail light. The reverse is the single wire, the turn, stop, and tail light wires are on a three pin connector. 1 Quote Link to comment
mjp1531 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Ok thank you :) I'm going to head under there with some windex and a rag to clean the gunk off. That way I can at least see what colors I'm working with lol. I'll try and get some pics of the truck itself posted later on today. Thanks again :) 1 Quote Link to comment
Charlie69 Posted June 18, 2015 Report Share Posted June 18, 2015 DanielC is the best I know of on 521 wiring! I know it but not to the extent that DanielC does. Down load the 521 Manual pdf and if needed print the pages you need. Quote Link to comment
mjp1531 Posted June 18, 2015 Author Report Share Posted June 18, 2015 So I've studied the diagram you gave me, but it doesn't look like what I have under the hood. Should I rearrange things, or leave them alone? This is what I have as far as wiring to the fusible link: 1 Quote Link to comment
mjp1531 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Here are a few more shots I managed to get. Sorry about the pics, I could barely see the screen due to the sun beating on us 1 Quote Link to comment
mjp1531 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Here is the truck as I received it: 2 Quote Link to comment
DanielC Posted June 19, 2015 Report Share Posted June 19, 2015 your truck will have some differences from the wiring diagram. The 1972 521 had an electric choke, not the manual choke that earlier 521 trucks used. Earlier 521 trucks do not have a fuseable link. Yours may not either. 1 Quote Link to comment
mjp1531 Posted June 19, 2015 Author Report Share Posted June 19, 2015 Ok, thanks. I thought the fuse box was the fusible link lol. I guess that's what happens when you spend hours online trying to track a fix down....all of the jargon gets confusing :p 1 Quote Link to comment
mjp1531 Posted June 19, 2015 Author Report Share Posted June 19, 2015 So the blue and black wires sticking out from underneath the air filter... What do those go to? 1 Quote Link to comment
Desertstalker Posted July 4, 2015 Report Share Posted July 4, 2015 Does your truck have a smog pump? If so the blue and black wire go to the solenoid that is located on the carburetor. Read the Haynes 510/521 manual and it will describe how the solenoid works, when it should be powered up and when it should not. It works in conjunction with the dual point setup for emission purposes! 1 Quote Link to comment
Charlie69 Posted July 4, 2015 Report Share Posted July 4, 2015 Do not re arrange your wires. I believe this is the wiring diagram for your year truck. Do yourself a favor and clean your engine bay. Much nicer to work on something clean! 1 Quote Link to comment
