brapattack Posted June 15, 2015 Author Report Share Posted June 15, 2015 Really? I had always heard that rwd cars needed the drive shaft disconnected because even in neutral the rear wheels moving would spin the gears and without the engine running it would overheat the trans since no fluid would be being pumped through it. Not sure how to test the trans on a non running car though. Any thoughts on the rust and 1 cylinder being way low PSI? I was happy about about the rust in most places but those frame rails worry me. Quote Link to comment
datsunfreak Posted June 15, 2015 Report Share Posted June 15, 2015 I had always heard that rwd cars needed the drive shaft disconnected because even in neutral the rear wheels moving would spin the gears and without the engine running it would overheat the trans since no fluid would be being pumped through it. There is no fluid pump in a Datsun manual transmission. The trans oils itself by slinging fluid around. Which I am 99% sure it does whether it's running or not. I could be wrong, but I've never broken one this way, so... Any thoughts on the rust and 1 cylinder being way low PSI? I was happy about about the rust in most places but those frame rails worry me. Sadly, the rails are beat/rusty on almost every S30 in Texas. It's all too common here... As for one cylinder being down, I personally wouldn't judge it on that just because it's sat for so long. Could just be stuck oil rings that may loosen up as you drive it? I would definitely use it as a bargaining chip in the negotiation, but it wouldn't scare me off fixing it. That, and good 280Z/280ZX engines are not exactly hard to find around here. Quote Link to comment
brapattack Posted June 15, 2015 Author Report Share Posted June 15, 2015 The rest of the frame looked pretty rust free. I wonder if I can just cut out the floors and the rail in that section and weld in a new one. Well I know other folk do it but I wonder if I should tackle something like that. I do weld in my usual work but all with an oxy/acetylene rig, no TIG. Quote Link to comment
datsunfreak Posted June 15, 2015 Report Share Posted June 15, 2015 The rest of the frame looked pretty rust free. I wonder if I can just cut out the floors and the rail in that section and weld in a new one. Well I know other folk do it but I wonder if I should tackle something like that. I do weld in my usual work but all with an oxy/acetylene rig, no TIG. FWIW, I am pretty decent/experienced with oxy-acetylene welding. Took me about 5 minutes to get passable with a wire-feed welder. You can do it. :thumbup: Quote Link to comment
petercscherer Posted June 15, 2015 Report Share Posted June 15, 2015 The rest of the frame looked pretty rust free. I wonder if I can just cut out the floors and the rail in that section and weld in a new one. Well I know other folk do it but I wonder if I should tackle something like that. I do weld in my usual work but all with an oxy/acetylene rig, no TIG. I agree with datsunfreak, you could very easily learn to MIG weld enough to get a lot of these issues fixed. Just takes time and materials. ~Peter Quote Link to comment
brapattack Posted June 15, 2015 Author Report Share Posted June 15, 2015 I actually have done some MIG before. Made some big motorcycle gurneys and other tables, stands and such. I just don't have my own machine. Quote Link to comment
datsunfreak Posted June 16, 2015 Report Share Posted June 16, 2015 Harbor Freight sells a beginner machine for $100? No gas, so it can be a little messy, but it sticks stuff together well. Quote Link to comment
brapattack Posted June 16, 2015 Author Report Share Posted June 16, 2015 I got the guy down to 1200. Is there any reason I can't torch the pans and frame rails? I mean that's what I'm good at and they used to brass braze racing frames so if done right it's plenty strong. Quote Link to comment
datsunfreak Posted June 16, 2015 Report Share Posted June 16, 2015 Is there any reason I can't torch the pans and frame rails? No, as long as... done right it's plenty strong. Quote Link to comment
datsunfreak Posted June 16, 2015 Report Share Posted June 16, 2015 Could be a slim chance of warping the panels if you get it too hot, though? And I mainly steered you to wire welding because you may have to do it laying on your back. ;) Quote Link to comment
Dolomite Posted June 17, 2015 Report Share Posted June 17, 2015 At 12 hundy, I'd jump on it. I got my 510 out of a pile of weeds and brush for $500, we had it running that night, l series shit is bullet proof. All the body parts for the Z are available, get it running so you can enjoy it while you work on it, do the rails and soforth when you can. Quote Link to comment
brapattack Posted June 17, 2015 Author Report Share Posted June 17, 2015 Thanks, I think I should just go for it. Feels. Little overwhelming getting into a project like this but that's just cause I need to wrap up a couple motorcycles. MIG would certainly be faster and I wouldn't have to clean up flux after. We'll see. My first order will be to get the gas lines, tank and AFM all mounted and probably get new injectors. Also going to get a rubber kit to replace all the seals right off the bat to slow anymore water getting into it. Just try to stop the decay while I turn the rest of it around. Quote Link to comment
Slowpoke Posted June 20, 2015 Report Share Posted June 20, 2015 Did you pick it up? Quote Link to comment
brapattack Posted June 20, 2015 Author Report Share Posted June 20, 2015 Not yet, I have the radiator out of my Ranchero right now and waiting for a part to show up so I can throw it back in. Didn't want to add a non-moving vehicle to my driveway until I get that back together. The part will either show up today or Monday so shouldn't be too long. Also, someone is coming to look at the Ranchero this week and if that sells then i'll probably use that money to buy a functioning Z that I can steadily improve rather than a long term project. Quote Link to comment
brapattack Posted June 21, 2015 Author Report Share Posted June 21, 2015 Here is what might be a strange question; how do the rear shocks/struts mount to the lower control arm/hub/knuckle on the 280z? I am asking because I would like to take this one in the opposite direction than most. Up with offroad tires like the 240z rally days. I know this might be blasphemy to most on here but seems like a fun direction to go. I would want to add just a couple inches with longer struts, or use a spacer maybe. Then add on tires that take up as much space as possible. Quote Link to comment
Slowpoke Posted June 21, 2015 Report Share Posted June 21, 2015 Did you just watch Mad Max? I think a rally style Z would be cool. I've seen pics of lifted Z's around, you wouldnt be the first but it is different. You can find all that in the factory manual at the top of this forum. You should probably read it one or twice before buying a 240. Quote Link to comment
brapattack Posted June 21, 2015 Author Report Share Posted June 21, 2015 I did see mad max but I actually started thinking it would be cool when I saw one of those AMC Eagle SX/4 that had been turned into something like that...and I thought a 280z would look pretty darn cool if I could figure out how to fit big mud tires on it. Quote Link to comment
datsunfreak Posted June 22, 2015 Report Share Posted June 22, 2015 Here is what might be a strange question; how do the rear shocks/struts mount to the lower control arm/hub/knuckle on the 280z? Single bolt. Quote Link to comment
brapattack Posted June 22, 2015 Author Report Share Posted June 22, 2015 Just looking at the diagrams and in the manual, it looks like it would be possible to put a spacer on the underside of the top mount in the car or at the base of the strut. The easiest would be to just get a longer strut assembly but most listing don't have raw dimensions, rather they list how much lower than stock it will be. Wanting to go in the other direction means finding something from a different vehicle most likely. First things first is getting that car to my place and doing some measurements on how tall of a time could fit in there with a stock setup. I know its got extra room as is, but also need to look into how much travel there is. Quote Link to comment
petercscherer Posted June 22, 2015 Report Share Posted June 22, 2015 Here's another 280Z that just popped up on the south-side of DFW. Looks pretty complete and solid. http://dallas.craigslist.org/sdf/cto/5085984529.html ~Peter Quote Link to comment
brapattack Posted June 22, 2015 Author Report Share Posted June 22, 2015 Thanks for the heads up, I sent them an email and we'll see what else I can find out about it. Quote Link to comment
Slowpoke Posted June 22, 2015 Report Share Posted June 22, 2015 You could fabricate a longer sleeve type coil over setup. Use a coil over kit with a threaded body, then extend the length of the tube that welds onto the spindle. This way you could still adjust the ride height by a few inches. Not sure how this would effect the suspension geometry, or ride safety but it would get the look. Or you could just lighten the stock body! That would get you up there with no suspension mods, haha. Quote Link to comment
brapattack Posted June 23, 2015 Author Report Share Posted June 23, 2015 Sounds like that blue one has belonged to the same family since it was bought in 1975. The father bought it and drove it for a few years before the son took it to college. Then it sat in their barn for over 15 years. No major wrecks. She didn't comment on rust or what might be wrong with it (other than usual sitting decay) but it sounds like a great candidate for fixing up. Going to try and get up to Dallas later this week to check it out. 1 Quote Link to comment
Slowpoke Posted July 14, 2015 Report Share Posted July 14, 2015 Pick one up yet? Quote Link to comment
brapattack Posted August 4, 2015 Author Report Share Posted August 4, 2015 Hey Slowpoke, I haven't gotten a Z yet but I really like this one: https://austin.craigslist.org/cto/5152002065.html The problem (not a bad one) is that my ranchero sold and I had to buy something else with a bed. So now i've got a first gen toyota pickup that im funneling cash into...If that black 260z was posted a month ago I would have picked it up, now i don't think its smart to buy a second vehicle in as many months. Quote Link to comment
