Power Steering Questions
Crazykidd9
  • Replies 9
Many 4x4 came with power steering and tilt. I have only seen a few 2wd with powersteering. Tilt column even fewer. I have had 6+ 720's(80-86) and only 2(83std-83kc) had the factory front sway bar.  If yours doesn't have power steering don't worry....easy to turn without. TILT in a std cab a must. Snag the swaybar and hardware off same truck if equipped.
  • 2 weeks later...
