L28 Exhaust Flange for Downpipe - mklotz70
mklotz70
Hi guys,
I've been asked about creating a manifold flange for the L28, like the 3/8" thick one I currently do for the 4cyl L-series.  I figured I check with you guys before I get too far along.
Are they available somewhere?  Is there a need/want for them?
If I'm going to move forward with this, I was wondering if there might be a local Z guy that has a stock flange or downpipe that I can borrow to verify dimensions.  I can get them close with the gasket, but not close enough to commit to a laser cutting order.
Thanks!
Mike
....pic of CAD....not yet to correct dimensions.
  • Replies 4
Hey mike. I'll bring the one off my 79280zx 2 canby....I'll need it back later.
I may have all the measurements I need.  Can you pm an email.  When I get the new CAD done, I'll send you a 1:1 pdf that you can print and compare to your flange.  If it's good, no need to bring the other. :)  I did the CAD work based on the exhaust gasket, but I've since found out that the flange looks more like the one for the 4 cylinder L-series engines.  Hmmmm......I should probably check that gasket against the flanges I already have!! I think they're a bit small.
