j_boy_619 Posted May 14, 2015 Report Share Posted May 14, 2015 If someone could provide me a link that would be great. I'm having no luck http://imgur.com/towV0cr http://imgur.com/U1HvHEQ Quote Link to comment
Doctor510 Posted May 14, 2015 Report Share Posted May 14, 2015 Make one! It's for the EGR, eBay etc. Quote Link to comment
j_boy_619 Posted May 14, 2015 Author Report Share Posted May 14, 2015 I was thinking about it. But if I can get one ready made, that would be nice. Well I need the one that's for that gap. Not the plate Quote Link to comment
j_boy_619 Posted May 14, 2015 Author Report Share Posted May 14, 2015 http://imgur.com/MpKUDRm http://imgur.com/Rjtlg3O Quote Link to comment
ericsb210 Posted May 14, 2015 Report Share Posted May 14, 2015 If you are not running the EGR, why are you retaining the unit? Take it off have a plate cut to match, make a gasket out of header gasket material. Looks much cleaner and dispurses the ex manifold heat. 2 Quote Link to comment
kelowg Posted May 14, 2015 Report Share Posted May 14, 2015 just need holes in gasket for bolt holes. Other holes no longer function. No need for hg material,intake dont get that hot. Quote Link to comment
j_boy_619 Posted May 14, 2015 Author Report Share Posted May 14, 2015 Hmmm I like this idea. I need to look into this now Quote Link to comment
ericsb210 Posted May 14, 2015 Report Share Posted May 14, 2015 I have cooked inferior gasket material over time. Header gasket material is one and done. Note; NOT Head Gasket material, use HEADER gasket material. Quote Link to comment
dat521gatherer Posted May 14, 2015 Report Share Posted May 14, 2015 I just recently replaced a wooden block off plate with something way better. See thread. Page 3 you can just barely see my a15 with my wooden block off plate. Page 5 shows my new plate. Use a old gasket or the egr housing for a template.http://community.ratsun.net/topic/59763-my-1980-datsun-b310-210/page-5 1 Quote Link to comment
datzenmike Posted May 14, 2015 Report Share Posted May 14, 2015 Every Datsun owner should have a dollar store hole punch. It makes holes and interior holes that can't be done with scissors easily. Just buy some gasket material. Almost anything will do here as it doesn't get that hot so far from the exhaust flow. If for an operating EGR then, yes something like for a header. 2 Quote Link to comment
dat521gatherer Posted May 15, 2015 Report Share Posted May 15, 2015 Actually a leather punch is way better but produces small holes. But you can do thick material with it like mr. gasket. Quote Link to comment
dr.feltersnatch Posted May 15, 2015 Report Share Posted May 15, 2015 https://www.rockauto.com/ Part # A37105 34 cents plus shipping Quote Link to comment
KELMO Posted May 15, 2015 Report Share Posted May 15, 2015 FWIW.....part # is 14719-N3301 if it is where the EGR valve mount to the manifold. Quote Link to comment
B210GX Posted May 15, 2015 Report Share Posted May 15, 2015 hole punch .38 cal shell works well also :thumbup: Quote Link to comment
KELMO Posted May 16, 2015 Report Share Posted May 16, 2015 I have used that process to make shims for my steering box out of Mountain Dew cans......yes, the hole punch worked on that too. Quote Link to comment
j_boy_619 Posted May 18, 2015 Author Report Share Posted May 18, 2015 thanks gents, took your advise and made a plate and me own gasket. 1 Quote Link to comment
