blueratsun Posted May 13, 2015 Report Share Posted May 13, 2015 I have a 82 datsun that has a 85 z24 motor in it with a 4 speed trans and running about 50 mph im running about 3500 rpm in 4th gear and was wondering how high i can gear the rear end. And if anyone knows where to shop for new gears for my rear end at? 1 Quote Link to comment
EastBay521 Posted May 13, 2015 Report Share Posted May 13, 2015 pick n pull or what ever wrecking you guys have where you are at. from another 720. 3.7 and 3.889 are very common 1 Quote Link to comment
]2eDeYe Posted May 13, 2015 Report Share Posted May 13, 2015 What ratio do you currently have back there? You might be better off sourcing a 5-speed. 1 Quote Link to comment
bryant2482 Posted May 13, 2015 Report Share Posted May 13, 2015 I used a 3.55 out of a hard body. And yea like DEYE said a 5 speed wouldn't be a bad idea either 1 Quote Link to comment
datzenmike Posted May 15, 2015 Report Share Posted May 15, 2015 Look under the pass side hood hinge on the inner fender for the engine tag. Stamped on the bottom row is the TRANS/AXLE ..... F4W71B..... HF43 The 43 means 4.375 ratio but could say 41 for 4.11 or 39 for 3.90. See what it says as 3,500 @50 isn't right. I assume you have a tack? and not going by engine noise? The 2wd Z24 powered trucks easily ran 3.90 or 3.70s in them. 3.545s were also used but will be sluggish. The Z24 is a torque monster and will pull them all. As mentioned gears from another 720 s the easiest and you can shop by looking at the engine tags. 2 Quote Link to comment
