DrRocks0 Posted May 12, 2015 Report Share Posted May 12, 2015 Where do you source the steering ujoint that is right after the firewall under the master cylinder? Mine quit today while on the freeway. Quote Link to comment
MikeRL411 Posted May 13, 2015 Report Share Posted May 13, 2015 Vehicle and year? Quote Link to comment
DrRocks0 Posted May 13, 2015 Author Report Share Posted May 13, 2015 68 510 but its converted to rack and pinion. 1 Quote Link to comment
MikeRL411 Posted May 14, 2015 Report Share Posted May 14, 2015 From the Pix there seems to be a broken C clip on the rail. Could the cure be as simple as cleaning out the recess and installing a new C clip? 2 Quote Link to comment
datzenmike Posted May 14, 2015 Report Share Posted May 14, 2015 quote: "68 510 but it's converted to rack and pinion" This info might have helped earlier. If it's custom how can someone offer anything but a poor guess? So what's original and what's not. What's the rack out of? Make and model? Is it even Nissan? 1 Quote Link to comment
hosestop@msn.com Posted May 15, 2015 Report Share Posted May 15, 2015 What rack and that angle looks like will eat again later ! 1 Quote Link to comment
datzenmike Posted May 16, 2015 Report Share Posted May 16, 2015 FWIW the 720 truck uses a small U joint in the column. That's what I thought that was.. There are several used in the early trucks but only one for the '83 and up 2wd. 48080-20W10 if you want to look it up. They ain't cheap so get one from a wrecked truck. 1 Quote Link to comment
Doctor510 Posted May 19, 2015 Report Share Posted May 19, 2015 http://www.ebay.com/itm/Datsun-Roadster-Steering-Box-U-Joint-65-69-/201345101616 1 Quote Link to comment
