btd19m Posted May 10, 2015 Report Share Posted May 10, 2015 so on the passengers side one of the leafs is out of the leaf pack at the moment at the rear end and im wondering if this is a serous problem or if i can just ignore it for now? i would get photos but its getting quite dark and i have 700 + cows to feed and really need to get that done and drive home. also my ride height is quite a bit lower then i would like for newish springs that is 10.6CM and its just over 15cm at the other end. 1 Quote Link to comment
datsunaholic Posted May 10, 2015 Report Share Posted May 10, 2015 Those are new? They look like 34 year old leaves that someone installed out of sequence. 1 Quote Link to comment
btd19m Posted May 10, 2015 Author Report Share Posted May 10, 2015 do you have any suggestions as to where to track down new leafs? the leaf "pack" on the other side has slid and a leaf is just floating. 1 Quote Link to comment
btd19m Posted May 10, 2015 Author Report Share Posted May 10, 2015 they were not ment for the datsun as far as i know the ford f150 we have as a tow car has the very same leafs in it and the drill holes in the leafs make me wonder. i do have a feeling they just moved them over when the f150 had the leafs replaces after it snapped an axle towing 11.2 ton. it had them replaced 4 months ago. still have the quote. just says springs/coils $1150 1 Quote Link to comment
Ratwagon1600 Posted May 10, 2015 Report Share Posted May 10, 2015 Try grand auto wreckers in Adelaide www.grandauto.com.au Baz at Datsport may know where to source them from as well www.datsport.com 1 Quote Link to comment
]2eDeYe Posted May 11, 2015 Report Share Posted May 11, 2015 If leafs are floating then the center pin is likely broken. You will need to replace it, this requires removing the u-bolts and axle to access it. 1 Quote Link to comment
