72 Wagon Fuel Filler neck to tank question
When I got my wagon the fuel tank was removed/bad.  I got a new tank and I'm putting it back in with new vent hoses and I think i'm missing a piece. Is there supposed to be a rubber section that goes onto the tank filler and then to the filler neck attached to the body?  Or is the plastic end of the filler tube supposed to slide over the tank filler tube?    I'm pretty sure i'm missing a piece......
  • Replies 5
I think the heat gun trick should be the ticket.  I got it over the tank inlet but it still seems a little short.  I'm going to heat it a little more with my heat gun farther up and see if I can stretch it down a little farther onto the inlet.  Thanks guys!!!
